Author Topic: IBM model M  (Read 1675 times)
Offline xpurpleturtlex
IBM model M
« on: Mon, 11 May 2015, 08:39:31 »
hey im new here and i was just wondering if someone could help me:
im playing this game called osu.. and when im pressing the buttons 4 at once just 2 of them work is there a way that this could have been changed so i could press more buttons at once or do i have to live with it?
Offline Lurch
Re: IBM model M
« Reply #1 on: Mon, 11 May 2015, 08:45:47 »
Welcome! Model M's have two-key rollover.
"A keyboard with "two-key rollover" can reliably detect only any two keys used simultaneously; in other words, a user can hold down any key on the keyboard and press a second key, and be sure that the keypress is correctly detected by the computer. However, if the user has two keys depressed and attempts to strike a third key, the third keypress may create a "phantom key" by shorting out the switch matrix."
Source: http://en.wikipedia.org/wiki/Rollover_%28key%29
Quote from: Flyersfan1
Offline E TwentyNine
    • Some of My Keyboards
Re: IBM model M
« Reply #2 on: Mon, 11 May 2015, 08:52:28 »
If you can use different keys you can find a combination.
Get the file linked here: https://geekhack.org/index.php?topic=34670.msg641440#msg641440
And try combos.  For four keys, QWER, ASDF, ZXCV  work,  as do UIOP, JKL;, M,./
(edit: punctuation...)
« Last Edit: Mon, 11 May 2015, 09:33:07 by E TwentyNine »
Offline Xonar
  • Cathode Ray Tubes
    • Winnebago
Re: IBM model M
« Reply #3 on: Mon, 11 May 2015, 08:53:02 »
It appears you require a Model F, which has unlimited (NKRO) because of it's capacitive sensing PCB.
Welcome to WalletHack!  ;)
IBM Model M SSK Industrial (Mopar) | Ellipse Model F77 (Industrial) | IBM Model F XT 5291 Bigfoot x2 | Unicomp UN4KPHA JP Spacesaver M | IBM Model M 3270 APL 122-Key | SHARP X68000 | Silicon Graphics AT-101 |  Samsung TH-5539 FAME Blue Alps | IBM Japanese Pingmaster | IBM Model M 1392595, 6/4/1990 | IBM Model M 1391401, 2/2/1988 | Lexmark-branded 1398601 Model M, 8/18/1995 | Apple Extended Keyboard II | Unicomp UB40T5A 122-Key, 5/20/2011 | Sun Type 4 | Sun Type 5c | DEC LK-401AA
Re: IBM model M
« Reply #4 on: Mon, 11 May 2015, 09:07:07 »
thanks for the help :D i found out a way that 4 keys work at the same time
