Author Topic: Possible to rig a topre keycap on a novatouch without taking it apart?  (Read 2658 times)
Offline Koobs
So basically I may buy a topre reaper off a guy, and im really thibking about it as I may buy a topre board in the future. Now my question is, can I rig it onto a novatouch stem without taking the board apart? Will the cap atleast sit on the board? Like ive nevee touched a topre cap so I have no clue. Any help is appreciated, and if I need to go the slider route, it is what it is.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
I don't believe it will really fit at all.
Bro's topre stems won't work on a Novatouch without quite a bit of modification.
Edit: You'd need to cut out the middle bit that holds the two halves of the topre stem.
Offline Koobs
So my only option is getting a topre keyboard, topre slider, or trading it for a mx reaper which seems less likely?
Offline Air tree
Pretty much.
Offline trizkut
I think I remember reading that Bro's squared MX stems don't fit in the novatouch sliders
Yeah but even an MX reaper won't work due to the rectangular stem. You'd need to sand it down for it to work on a Novatouch.
Edit: trizkut beat me by 1 sec  :))
