Author Topic: Poker II Help with USB 3.0  (Read 1218 times)
Offline ARAMP1
« on: Sun, 17 May 2015, 17:17:53 »
I did a little searching, but couldn't find the answer.
I'm trying to use a Poker II into a USB 3.0 but I keep getting the error "The USB Composite Device is connected to a hub that does not have enough power available to support it".  There's nothing else connected to the USB 3.0 hub, other USB peripherals work just fine with it.  It seems to be an issue with the keyboard only.  And when I connect to the USB 2.0, the keyboard works fine.
I would just leave it hooked to the 2.0 hub at the back of the computer tower, but my cable is too short to be convenient, where the 3.0 hub is easily within reach.
Any suggestions are appreciated.
