Author Topic: Toshiba 3100e diodes  (Read 1911 times)
Offline JohnElliott
« on: Sun, 20 September 2009, 14:24:53 »
I'm trying to repair a Toshiba 3100e keyboard (ALPS keyswitches, double-shot keys) on which the Escape key doesn't work. The switch itself is fine, so I need to replace the associated diode (especially after I desoldered it and it came out in two halves!)
Any suggestions on the correct rating for a replacement diode?
Offline Rajagra
« Reply #1 on: Sun, 20 September 2009, 14:38:28 »
A 1N4148 or 1N914 should be OK. Specs aren't critical for diodes in an apilcation like this.
Offline JohnElliott
« Reply #2 on: Mon, 21 September 2009, 13:15:17 »
Thanks for the info.
