Author Topic: did i buy the wrong type of stabilisers?  (Read 3013 times)
Offline snipars
« on: Tue, 19 May 2015, 18:48:55 »
I'm building a duck octagon with gateron switches, and i've realised that the stabilisers i've bought are PCB-mounted stabilisers, when the switches are mounted to the octagon's plate
is it possible for me to use these stabilisers, or should i try to find somewhere to buy plate-mounted stabs?
Duck Octagon + Gateron Black |HHKB Pro 2 | Poker 2 + Vintage Black + Tex case | Unicomp Ultra Classic | WASD V2 |
Re: did i buy the wrong type of stabilisers?
« Reply #1 on: Tue, 19 May 2015, 19:00:54 »
If you have holes in the PCB to fit the stabilisers into you can use them, the switches and stabilisers are the same height whether plate or PCB mounted :)
Offline snipars
« Reply #2 on: Tue, 19 May 2015, 19:02:42 »
oh ok, though the spacebar seems a bit wobbly, not exactly stabilised
« Reply #3 on: Tue, 19 May 2015, 19:03:10 »
Duck octagon only supports PCB mount stabilisers, like most Korean boards. You got the right ones.
Offline snipars
« Reply #4 on: Tue, 19 May 2015, 19:08:12 »
okay cool, though the space bar does not seem stabilised
« Reply #5 on: Tue, 19 May 2015, 19:10:27 »
Is the stabiliser wire the right size for your spacebar? When the stabiliser is assembled do the stems match up with the holes of your spacebar?
Offline snipars
« Reply #6 on: Tue, 19 May 2015, 19:11:33 »
yeah it's a 6.25 spacebar and 6.25 stabiliser
« Reply #7 on: Tue, 19 May 2015, 19:13:55 »
Then there is something that is not sitting right. Where is it loose?
The stabiliser should consist of two slider parts, two base parts and a metal wire. The wire should be snapped to each base part and have its ends inside a square hole in the side of each slider. It is a bit fiddly.
Each slider should fit into a cross-shaped hole at the bottom of the space bar.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #8 on: Tue, 19 May 2015, 19:16:01 »
Could you take a picture of it maybe?
Offline snipars
« Reply #9 on: Tue, 19 May 2015, 19:17:29 »
i'm not really sure how i could show the issue in a picture, i think i'm assembling the stabs wrong, i just can't seem to figure it out
ah, i had the metal wire underneath the slider, not in the square part
it seems when i try to put the wire into the square part of the slider, it can't go far enough in to snap to the base part
« Last Edit: Tue, 19 May 2015, 19:24:06 by snipars »
