Author Topic: Keyboard issue on alienware laptop  (Read 3460 times)
Offline soutwest_kill3r
« on: Fri, 22 May 2015, 07:51:18 »
Can someone help me out please.  I just bought a i7 alienware laptop,  but the ENTER button doesn't work. Nor the number 1 or 3.
Mod Edit: Edited title to make it more accurate.
« Last Edit: Sat, 23 May 2015, 09:23:04 by infiniti »
Offline baldgye
  • Will Smith Disciple
Re: Keyboard issue
« Reply #1 on: Fri, 22 May 2015, 07:52:35 »
strange, this isn't the alienware support line... is it?? IS ITT??!!!
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Keyboard issue
« Reply #2 on: Fri, 22 May 2015, 08:27:39 »
If it's brand new you should definitely send it back or contact Alienware support and get it RMAd.
Offline VoteForDavid
    • Vote For David
Re: Keyboard issue
« Reply #3 on: Fri, 22 May 2015, 18:45:00 »
...and if it's used, contact eBay for a replacement keyboard.
Jesus loves you.
Offline ander
  • I type, therefore I am
Re: Keyboard issue
« Reply #4 on: Sat, 23 May 2015, 03:11:26 »
Ask Sheldon. He uses one.
Re: Keyboard issue
« Reply #5 on: Sat, 23 May 2015, 08:59:05 »
Keep keyboards out of off topic
Mfw I'm not even in off topic.
Ignore me I'm retarded
Mfw mfw infiniti moves it from off topic.
I'm so confused
« Last Edit: Sat, 23 May 2015, 09:58:49 by demik »
Offline katushkin
  • Just the guy
Re: Keyboard issue
« Reply #6 on: Sat, 23 May 2015, 10:14:44 »
I'm so confused
TBF, you posted that first comment just before it got moved.
I think.
Offline infiniti
  • I <3 KB
  • Bob was here
Re: Keyboard issue
« Reply #7 on: Sat, 23 May 2015, 10:19:00 »
I'm so confused
I think.
Oops.
It was in off topic when demik posted that comment.
Re: Keyboard issue on alienware laptop
« Reply #8 on: Sat, 23 May 2015, 11:05:58 »
Okay so I'm not going crazy. Good to know.
Offline jamster
« Reply #9 on: Mon, 01 June 2015, 05:27:33 »
I still wouldn't rule it out ;)
