Author Topic: [GB] Matt3o's Amazing Topre PBT Spacebars  (Read 125401 times)
Offline a_ak57
Re: [GB] Matt3o's Amazing Topre PBT Spacebars
« Reply #250 on: Sat, 26 September 2015, 15:31:24 »
Got mine today.  My black keyboard is at work so I can't compare that one, but the white matches up really closely with my HHKB.  You can tell that the shade is a bit different if you actually look closely, but under normal viewing conditions the PBT bar looks right at home with the rest of the keys.  All of my bars have no warping that I can notice, so I'm happy with that as well.  The blue and red bars look nice too.  I really only bought those just because, but I may actually consider using the red one in conjunction with a red ESC.  I took pics of the white bar and the red setup:
112012-0
112014-1
« Last Edit: Sat, 26 September 2015, 15:41:23 by a_ak57 »
Offline strict
  • TKL Zealot
« Reply #251 on: Sat, 26 September 2015, 18:16:18 »
Got mine today, no warping and color match looks great. Will post some pics in a bit.
Offline Bucake
« Reply #252 on: Sat, 26 September 2015, 18:17:39 »
thanx for pix! :D
mine still have some flying to do, but i'm hyped :)
would anyone care to get my (white RF 87U) ABS spacebar, if i can find a cheap way to send it?
« Last Edit: Sat, 26 September 2015, 18:23:18 by Bucake »
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #253 on: Sat, 26 September 2015, 18:20:31 »
It seems my spacebar is going to take a bit longer in the mail.
Curse you and your expected delivery date.  :'(
Offline XMIT
  • formerly jsoltren
« Reply #254 on: Sat, 26 September 2015, 20:07:07 »
Mine is delayed due to a processing exception as well. Argh.
Offline Coin-op Adjutant
  • Official Toga Llama
« Reply #255 on: Sun, 27 September 2015, 09:44:51 »
Dunno about forcible delays but mine sure didn't hit the estimated date, haha.  I wouldn't have thought it would be delayed down south, though maybe that was just USPS jumping the gun.
a_ak57, I'm guessing that's a red ESC from EK?  If so, I'll have t okeep an eye out for a restock on the blank reds.  Both I and my FC660C are quite excited.
Does anyone know if the blue PBT spacebar matches the blue ESC from this EK set: https://elitekeyboards.com/products.php?sub=access,toprekeys&pid=pd_kb400kt01 ?  If so, well, shoot.  I may have to get a HHKB to match as well...
KEYBOARDS OWNED:
CM Storm QuickFire Rapid (MX Blues)  ||  CM Storm QuickFire TK (MX Blues) || Model F XT (Capacitive buckling spring, repaired and spray-painted black) || Leopold FC660C (Topre 45g, white/gray dyesub)
MICE/OTHER PERIPHERALS OWNED:
Logitech G9X (x2)  ||  Razer Deathadder 2013  ||  CM Storm Spawn  ||  Razer Sabertooth  ||  Hori Fighting Stick VX (360/PC)  ||  CM Storm Reaper
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #256 on: Sun, 27 September 2015, 10:09:30 »
yes it does... at least we tried :)
Offline Bucake
« Reply #257 on: Sun, 27 September 2015, 10:46:02 »
it's in stock on EK:
https://elitekeyboards.com/products.php?sub=access,toprekeys&pid=hh_redescn
so.. the blank red (H-REDESCN) color-matches the limited edition red ctrl(caps lock), and also the red pbt spacebar?
also, is there a blank blue left ctrl(caps lock)?
also, why do i buy everything?
help
« Last Edit: Sun, 27 September 2015, 10:58:32 by Bucake »
Offline Polymer
« Reply #258 on: Sun, 27 September 2015, 12:19:48 »
Always hard to say but...
The Red Topre ESCs I've seen are darker than the red ctrl...which might be different than the red RF set although in some pictures they look the same and some they look different...
I'll be able to compare it to the red esc I have and the red RF set I have once I get them in..
Offline a_ak57
« Reply #259 on: Sun, 27 September 2015, 12:43:27 »
Yeah, the red ESC is indeed darker than the spacebar.  I thought that was just due to the difficulty of matching perfectly, but since the red ctrl looks brighter I'm guessing matteo matched that for the spacebar.  Your mileage may vary but I don't find the difference in shade that much of a bother anyway, but the ESC and spacebar are fairly far apart so maybe it'd be more of an issue when you have the ctrl there too.
« Last Edit: Sun, 27 September 2015, 12:45:20 by a_ak57 »
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #260 on: Sun, 27 September 2015, 12:44:39 »
yes red is matched to ctrl.
Offline TopreFan333
« Reply #261 on: Mon, 28 September 2015, 00:39:44 »
I do feel like my HHKB spacebar (white) now has a nice, deeper sound when pressed. I cannot even remotely tell the difference visually, but will in a few months when it still doesn't have any shine on it :)
Offline Air tree
« Reply #262 on: Mon, 28 September 2015, 16:56:49 »
Got my PBT spacebar in the mail today and it's wonderful, the sound is a much deeper thunk, rather than the sharp "clack" that the ABS one had, I haven't heard the difference between PBT and ABS as large as this one.
The only bad moment was when I was trying to take it off again after putting it back on, to loosen it as matt3o said, It hurt my thumbs like hell. It was almost impossible to get off, a bit painful.  :))
Now that it's on in it's correctly flipped manner, all is well.
Offline Baxter
  • They do not know it, but they are doing it.
    • http://www.darklightweb.co.uk
« Reply #263 on: Mon, 28 September 2015, 17:27:22 »
Mine arrived too, colour and texture are perfect, all praises to Matt3o!
Offline Bucake
« Reply #264 on: Mon, 28 September 2015, 19:16:55 »
mine apparently haven't moved since the 25th :(
Processing Completed at Origin
Fri, September 25, 2015 at 12:30 PM ET
Secaucus, NJ, US
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #265 on: Mon, 28 September 2015, 20:44:02 »
You better do that because he is the FIRST one ever to make an all PBT space bar for the Thorpie regime.
While others would talk about it for years and make empty promises, Matt3o got on with the job to produce it, you better thank him for this  :thumb: .
Offline Charizard
« Reply #266 on: Tue, 29 September 2015, 00:58:32 »
I'm looking for a set of these if anyone has extras :)
Offline XMIT
  • formerly jsoltren
« Reply #267 on: Tue, 29 September 2015, 04:39:57 »
Mine are still stuck in Brooklyn with a Processing Exception. I hope I see them this week.
Offline KatzenKinder
« Reply #268 on: Tue, 29 September 2015, 05:04:16 »
Super pleased with the color and feel :)
Offline swimmingbird
  • keyset hoarder
« Reply #269 on: Tue, 29 September 2015, 05:45:06 »
Looks great with that V2!
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #270 on: Tue, 29 September 2015, 05:51:19 »
Mine says delivered but I don't have them. :(
Offline Elrick
  • Hype Master
« Reply #271 on: Tue, 29 September 2015, 06:05:26 »
Maybe your friendly next door neighbour, took the package and now they're residing in his RF keyboards  :p .
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #272 on: Tue, 29 September 2015, 06:14:36 »
That jerk would do that. However, I don't think he even knows what a computer is.
Offline Bucake
« Reply #273 on: Tue, 29 September 2015, 06:39:40 »
i've had a package delived at 11, while i live at 17. could something similar have happened?
Offline XMIT
  • formerly jsoltren
« Reply #274 on: Tue, 29 September 2015, 11:20:56 »
Mine have arrived. I'll upgrade MrsXMIT's keyboard this evening.
Offline Khers
  • Schrödinger's box
« Reply #275 on: Tue, 29 September 2015, 14:28:24 »
Secaucus, NJ, US
Same for me :(
Offline admiralvorian
  • DIY
« Reply #276 on: Tue, 29 September 2015, 17:10:37 »
same here :(
Darude Status:
☐ Not Sandstorm
☑ Sandstorm                                               wts wtt wtb
Offline perost
« Reply #277 on: Tue, 29 September 2015, 17:14:07 »
That's because DHL apparently doesn't bother tracking these kinds of packages once they leave USA. Using the tracking number displayed under "Delivery by Postal provider" on the DHL page with trackitonline.org shows that my package (on it's way to Sweden) has just arrived at "international place of exchange", whatever that means.
Offline Elrick
  • Hype Master
« Reply #278 on: Tue, 29 September 2015, 18:52:40 »
It happens here as well.  Problem is if I go personally down to his place to ask for any of my packages, there will be an all out fight, just can't help myself when I see his stupid face.
Hence I send the Mrs, she has a way of extracting anything from anybody, quite easily  8) .
Offline neunelfer
  • HHKB Pro
« Reply #279 on: Tue, 29 September 2015, 18:59:03 »
Space bars are awesome, forgot I had ordered two sets of white + black.
Unfortunately, both of my black space bars have pretty obvious mold/swirl lines on them. The white has it but it's not nearly as noticeable.
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #280 on: Tue, 29 September 2015, 21:17:32 »
Got mine in today. The texture on the cap got me like  :D :D :D :D :D :D :D
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #281 on: Wed, 30 September 2015, 02:15:46 »
it appears to be superficial, I had a couple of those, try to clean it with a soft cloth and isopropyl alcohol.
Offline Bucake
« Reply #282 on: Wed, 30 September 2015, 05:08:00 »
the track'n trace is no good, so i'm just hoping and waiting..
any outside-of-the-US-person with an update to theirs? :)
Offline perost
« Reply #283 on: Wed, 30 September 2015, 05:29:53 »
I'm able to track my package using the Swedish post now, by using the tracking number provided by DHL. Unfortunately it says that my package is stuck in Swedish customs at the moment. I have a feeling my spacebars are going to turn out to be very expensive...
  • keyset hoarder
« Reply #284 on: Wed, 30 September 2015, 05:34:42 »
"Transportation to Destination Country"
I hate dhl
Offline Elrick
  • Hype Master
« Reply #285 on: Wed, 30 September 2015, 05:51:02 »
Here in Australia no sign of them here yet.  But hey this is the postal service hence you get use to their tardiness when it comes to expecting your gear to arrive at a timely manner.
Offline yomammary
« Reply #286 on: Wed, 30 September 2015, 07:53:36 »
Just want to say that I got my spacebars, no Topre keyboard (soon) but they look great.
RF 87u 55g | Leeku 1800
Offline Hypersphere
« Reply #287 on: Wed, 30 September 2015, 08:24:50 »
My spacebars arrived yesterday. It is a wonderful feeling to see the first full-size PBT spacebars for Topre-switch keyboards. Thanks, Matt3o!
Offline oscillik
    • music podcasts
« Reply #288 on: Wed, 30 September 2015, 12:56:17 »
spacebars arrived today. I am amazed at how well these have turned out. The holy grail of Troper.
The colour matching is damn near perfect. I honestly didn't expect them to be so close.
« Last Edit: Wed, 30 September 2015, 12:59:30 by oscillik »
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Offline Bucake
« Reply #289 on: Thu, 01 October 2015, 07:05:11 »
i got an update today. it said the bars have arrived in Frankfurt (DE).
my guess is i receive them early next week :)
Offline raymogi
« Reply #290 on: Thu, 01 October 2015, 07:06:55 »
I freaked out when it says arrived in destination country in DEFRAA. It was supposed to be delivered to Indonesia xD
Please feed my addiction.
« Reply #291 on: Thu, 01 October 2015, 07:11:30 »
USPS finally got their stuff together; the spacebars arrived yesterday.
Will probably post pics later, but oh my goodness these look so nice on my Leopold.  Feels great, too.  One thing to note is that it took a couple tries to properly seat my blue one on the stabilizers--they rattled like crazy the first couple of times, and on the third time I seem to have got it right.
Anyways, good stuff.  The Leopold's plate-mounted "thock" works so well with the deeper tone of the PBT spacebars.  Love 'em, and thanks again Matt3o for doing this.  I just need matching ESC and/or CTRL sets to do them justice.  :D
KEYBOARDS OWNED:
Offline TopreFan333
« Reply #292 on: Thu, 01 October 2015, 11:10:51 »
Can people please post more of their experience with their local shipping service? I know this is a forum about keyboards, but I really stick around for the shipping anecdotes.
Offline TopreFan333
« Reply #293 on: Thu, 01 October 2015, 11:12:35 »
Same on my HHKB. I really bought them for the durability, but it never occurred to me how much deeper and better these would sound when hit!
Offline neunelfer
  • HHKB Pro
« Reply #294 on: Thu, 01 October 2015, 17:09:33 »
After a decent amount of rubbing with IPA, the marks are less noticeable. Thanks Matt3o!
Offline daviswalkers
  • HHKB Amature 2
    • Graphic Design Portfolio
« Reply #295 on: Thu, 01 October 2015, 17:23:29 »
You could also try #flippedspacebarmasterrace which would show way less of the side of the spacebar to hide any remaining residue!
Compact-SQ |          VE.A
 65g Zealios    |      78g Zealios
Offline robertsig
« Reply #296 on: Thu, 01 October 2015, 18:33:03 »
I got mine in.  Wow...very nice.  You can't tell by weight, but if you if hit both of them on the side of your desk, you can tell it's more substantial by the lower clunk instead of a higher-pitched clack.  Once installed, you can tell easily too.
Thanks for the group buy!
Offline chiefgrillz
« Reply #297 on: Thu, 01 October 2015, 19:38:49 »
wow they look great, nice to see them finally arriving
for those of us unlucky enough to miss out matt3o any thoughts on another round?
if anyone has any unwanted space bars who need a good home please message me.. i have hungry 87Us to feed  ;D
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #298 on: Fri, 02 October 2015, 08:18:51 »
I received my space bars today.
Thank you Sir Robotus Emeratus for making this happen.
Offline daerid
    • Rossipedia
« Reply #299 on: Fri, 02 October 2015, 12:30:46 »
Just got mine in the mail yesterday and got around to putting one on this morning. Was surprised at how much rougher than the stock keycaps it is, but I think I can get used to it. Thanks Matt3o for all your hard work!
