Author Topic: Which keyboard kits/PCBs support RGB Switches?  (Read 1456 times)
Offline trauring
    • off on a tangent
« on: Mon, 25 May 2015, 09:39:41 »
Which keyboards, keyboard kits, or plain keyboard PCBs support RGB switches? I noticed the recent Octagon GB supported RGB switches. What others do?
Also, do all RGB switches that are MX-compatible have their contacts in the same order? i.e. is there a standard?
Thanks.
Offline Blaise170
  • ALPS キーボード
    • XYZ
Re: Which keyboard kits/PCBs support RGB Switches?
« Reply #1 on: Tue, 26 May 2015, 13:45:44 »
AFAIK Cherry RGB have the same leads and as such should support any PCB with backlight, but I don't know for sure. Kailh on the other hand has four leads.
