Author Topic: broken Model M cable  (Read 3193 times)
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« on: Mon, 25 May 2015, 18:59:32 »
One of my two Model M PS/2 cables (the SDL type) lost two of its pins (on the PS/2 part) a while ago. I've got a few other PS/2 cables lying around and I was wondering whether it was possible to somehow put the head of another cable onto this one, which I guess should be possible, right? Could anyone tell me what to do exactly? I haven't taken the head off the cable yet out of precaution. Cheers!
Offline reset
Re: broken Model M cable
« Reply #1 on: Mon, 25 May 2015, 20:37:10 »
Some PS/2 cables only came with 4 pins. (Two of the pins don't seem to have a function.) It may be that the "missing" pins were never there in the first place. Google "PS/2 pinout" to see if the unused pins correspond to what's missing. If that's the case with yours, it will work fine.
« Reply #2 on: Mon, 25 May 2015, 20:59:05 »
It shouldn't be too hard to figure if you have a multimeter.
- D Trump 2026-10-24
Offline chyros
  • a.k.a. Thomas
« Reply #3 on: Tue, 26 May 2015, 03:21:37 »
Looks like it's pins 1 and 5 that are missing. Which sound somewhat critical.
So do I just shop off the end and reconnect it to another head? In what way do I use the multimeter for it?
« Reply #4 on: Tue, 26 May 2015, 08:15:58 »
First, remember that you are looking at the socket and not the plug in the diagram. Everybody makes that mistake.
Second, can you tell which wire is connected to which pin?
Third, "Fohat's Rule":
NEVER  TRUST  COLOR !
Offline greath
  • A waffle is like a pancake with a syrup trap.
« Reply #5 on: Tue, 26 May 2015, 08:19:08 »
If you can't fix it you could always buy a new one: http://www.clickykeyboards.com/index.cfm/fa/categories.main/parentcat/9417
Offline chyros
  • a.k.a. Thomas
« Reply #6 on: Tue, 26 May 2015, 12:28:24 »
NEVER  TRUST  COLOR !
Wait, so it's actually 2 and 6 I'm missing? Oo
« Reply #7 on: Tue, 26 May 2015, 12:42:32 »
Or, instead of worrying about all of this, you could just pick up one of the SDL to USB cables on eBay.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #8 on: Tue, 26 May 2015, 13:46:19 »
Then it should work just fine.  You may need an active PS/2 to USB adapter, if you don't have one already.
Offline chyros
  • a.k.a. Thomas
« Reply #9 on: Tue, 26 May 2015, 16:48:22 »
I have two cables and one Model M left so I don't need it. I was just wondering if I could fix it, as a backup.
Cool, cheers! I'll try it out next time.
Offline berserkfan
« Reply #10 on: Wed, 27 May 2015, 07:46:28 »
NEVER  TRUST  COLOR !
This is a 100% correct rule. That said, I really hate it. I wish international governing bodies should all get together and agree that red means power and black means ground and that anyone who refuses to produce to that standard should not be allowed to export his electronics.
Offline chyros
  • a.k.a. Thomas
« Reply #11 on: Thu, 28 May 2015, 13:41:00 »
It works! Good thing I hadn't chopped off the head yet xD . It probably didn't work at first because I'd tested it with a cold start, which doesn't work on a non-native PS/2 port, I later found out. Cheers guys!
