Author Topic: Saw this switch on ebay, looks like an Alps mount of some kind  (Read 2356 times)
Offline Blaise170
  • ALPS キーボード
    • XYZ
Is this an Alps slider rubber dome? Can't tell. Labeled as "silent" by the seller. Otherwise I've got nothing.
Re: Saw this switch on ebay, looks like an Alps mount of some kind
« Reply #1 on: Tue, 26 May 2015, 14:13:00 »
It does look suspiciously like a slider over rubber dome.  The Deskthority Wiki has a picture of one that looks very much like it except that the slider is white: it is called "Tulip dome with slider".
Does the keyboard look like one of these otherwise?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #2 on: Tue, 26 May 2015, 14:31:24 »
Well it is a Tulip branded board so I'd say you are correct. :P
Offline Touch_It
« Reply #3 on: Tue, 26 May 2015, 16:06:19 »
The keycaps are at least alps mount double shot, though they look thin.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Tue, 26 May 2015, 16:47:09 »
Weird to have nice doubleshots and then use ****ty domes with slider.
I haven't heard of any kind of thick Alps-mount doubleshots yet. All the ones I've seen and heard of are thin.
