Author Topic: [GB] Modern Selectric  (Read 174933 times)
Offline Rychubil
Re: [GB] Modern Selectric
« Reply #50 on: Thu, 12 July 2018, 05:34:53 »
So, I finally polished all matte Maxkey Black caps needed to put them on the Poker. I put on some non-polished F1-F5 caps for comparison and here's the effect:
https://imgur.com/a/Qm4wTb5
Pok3r, Core 47, JD40, OLKB Planck soon (in assembly).
Cherry MX clear, green (150g), Kailh BOX Navy.
SA: Ice caps, Dasher, T0mb3ry Carbon, Maxkey Black, Maxkey dolch, Matt3o/dev/tty MT3. DSA: Dolch, Contrast white, DSA Glimy 2077. Datamancer Typewriter Classic.
Offline elfick
  • Can I get Colemak and a side of fries with that?
« Reply #51 on: Mon, 16 July 2018, 19:15:57 »
All you used was your thumb?
Offline Rychubil
« Reply #52 on: Mon, 16 July 2018, 19:29:08 »
Yes, usually I used thumb and also pointing finger.
Offline booleanjulien
« Reply #53 on: Tue, 05 March 2019, 18:21:35 »
I may run another round at some point.
About that time now eh?
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
« Reply #54 on: Wed, 29 May 2019, 12:05:27 »
DSS?
Offline equalunique
« Reply #55 on: Wed, 29 May 2019, 14:56:01 »
DSS?
I'd like to see another run of Modern Selectric. Not sure yet if I prefer DSS over SA, but will know more after I try out DSS Dolch (waiting on the ortho kit).
