Author Topic: Stem location modification possible?  (Read 1930 times)
Offline zenless
« on: Wed, 27 May 2015, 10:49:35 »
Couldn't figure out a good way to search for this. But i take it keycap modification is not an easy task? What I mean is i have an off-center space key and an off center capslock. If i wanted to convert those to centered..that's not something a novice could easily do? Probably better off buying a modifier set? Anyone know of a good source of cherry or oem profile blanks for that purpose?
Offline greath
  • A waffle is like a pancake with a syrup trap.
Re: Stem location modification possible?
« Reply #1 on: Wed, 27 May 2015, 10:51:04 »
Offline zenless
« Reply #2 on: Wed, 27 May 2015, 10:54:04 »
http://imgur.com/a/9pkkr
Cool thanks! So must sacrifice a couple of caps :)
Offline iAmAhab
  • Established member
« Reply #3 on: Wed, 27 May 2015, 12:00:46 »
If you are careful you can reuse the one you cut away. Get a razor blade and break it to make it fit inside the cap. Then use some tool to slide it through the stem. Then just relocate and glue.
Offline Dongulator
« Reply #4 on: Thu, 28 May 2015, 09:34:30 »
