Author Topic: [GB] Premium O-Rings of Various Sizes >PRICES LOWERED<  (Read 12875 times)
Offline doodersbrother
« on: Thu, 28 May 2015, 21:11:54 »
This is a group buy for various O-ring sizes.
101933-0
1.5mm O-Rings (will be clear instead of black)
101935-1
2mm
101937-2
2.5mm
101939-3
3mm
101941-4
All the O-rings from smallest to largest
Price Tier
1 order - 0% off base price
10 orders - 10% off base price
20 orders - 15% off base price <-- we are here
40 orders - 20% off base price
Quantities:
60% includes 65
TKL includes 90
Full size includes 110
Prices
1.5 mm
60% $4.49
TKL $5.24
Full size $ $5.99
2mm
60% $5.49
TKL $6.24
Full size $6.99
2.5mm
60% $6.49
TKL $7.24
Full size $ $7.99
3mm
60% $7.49
TKL $8.24
Full size $ $8.99
Order here
Deadline is June 6 and all the o-rings will be ordered on that date as well. Once the o-rings arrive (5~ days) I will ship them all out within 1 week.
« Last Edit: Mon, 01 June 2015, 15:45:45 by doodersbrother »
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
Re: [GB] Premium O-Rings of Various Sizes >PRICES LOWERED<
« Reply #1 on: Fri, 29 May 2015, 21:48:31 »
Hello! Make sure you check "0" if you are not buying anything from that particular variant. Unfortunately, this is the only method for requiring responses that Google Docs supports for grids.
Thank you for including the "0" which didn't show on my first form when filled, only 1,2,3 and 4 columns had been presented.
Placed order and now waiting for the official bill to arrive  :thumb: .
« Reply #2 on: Fri, 29 May 2015, 21:49:42 »
Haha sorry, I can't believe I forgot the "0". Thanks!  :D
Offline RavenII
« Reply #3 on: Fri, 29 May 2015, 21:52:29 »
Now, on to more important questions...which one would be the "standard" size? 1.5mm?
« Reply #4 on: Fri, 29 May 2015, 21:54:57 »
The first option! Although it really depends on your keycap profile. For example, 1.5mm isn't ideal for SA haha.
« Last Edit: Fri, 29 May 2015, 21:57:35 by doodersbrother »
Offline Elrick
  • Hype Master
« Reply #5 on: Fri, 29 May 2015, 21:55:38 »
Depends upon the key profile you are currently using which are a lot here on Geekhack central.
I like the different sizes being presented for sale here because you can successfully dampen DSA's, Cherry Profiled (normal), OEM and believe it or not even the SA can be damped with a few 3mm silicone rings applied per key.
« Last Edit: Fri, 29 May 2015, 21:58:45 by Elrick »
Offline RavenII
« Reply #6 on: Fri, 29 May 2015, 23:44:31 »
Yeah, right now I'm using the 70a? from Amazon (the $3 ones) and it almost seems as if though they shorten the throw of these Cherry profiled caps, but are fine for OEM profile...that's why I was wondering. I guessi it wouldn't hurt to buy a bit of both and experiment...I mean, I only have...6 keyboards...
Edit: These are the ones... and it appears as if they're 1.5mm thick...I definitely can't do any thicker than them...
« Last Edit: Fri, 29 May 2015, 23:49:50 by RavenII »
« Reply #7 on: Fri, 29 May 2015, 23:57:32 »
70A must be horrible to type on. I can't imagine how stiff they are.
Offline RavenII
« Reply #8 on: Sat, 30 May 2015, 00:02:54 »
To be honest, they aren't that bad, I mean, realistically they're no worse than typing without them. They do what I need...and that's dampen sound....I just need clears for my next build because of the backlighting...But if the 1.5mm clears are anything like the banggood ones...they're just a hair too thin, so I'm trying to decide between 2 and 1.5....
Offline Elrick
  • Hype Master
« Reply #9 on: Sat, 30 May 2015, 00:34:18 »
Not at all especially if they are certified Korean made springs  :thumb: .
Always loved the heavy springs because my paws are heavy-gauge hence they need some resistance to type effectively, like watching a bear type.
Offline JordiOrlando
  • I make stuff
« Reply #10 on: Sat, 30 May 2015, 02:43:02 »
70A refers to the durometer of the O-rings, not the stiffness of the springs.
Offline Elrick
  • Hype Master
« Reply #11 on: Sat, 30 May 2015, 05:29:49 »
Thanks buddy, you always learn something new when you visit Geekhack  8) .
« Reply #12 on: Sat, 30 May 2015, 13:17:29 »
Haha yeah you confused me there.
Offline Gaspar
« Reply #13 on: Sat, 30 May 2015, 17:08:36 »
Are those rings 40A?
« Reply #14 on: Sat, 30 May 2015, 18:18:51 »
These are 50ShoreA! Very soft in my opinion
Offline Azumia
« Reply #15 on: Sun, 31 May 2015, 06:22:35 »
Just placed my order! :>
Looking for Granite Mono Legends and Icon Modifiers~ https://geekhack.org/index.php?topic=73646.0
« Reply #16 on: Sun, 31 May 2015, 13:40:53 »
Awesome, thanks!
« Reply #17 on: Mon, 01 June 2015, 01:37:48 »
We need just a few more orders to get to the next price break!
Offline Grrizz
« Reply #18 on: Mon, 01 June 2015, 15:02:01 »
Just put mine in... hope that tips it for us ;)
« Reply #19 on: Mon, 01 June 2015, 15:47:24 »
Yep, that did it! We're in the next price tier now!
