Author Topic: [IC] The TK78, a custom 78 Key 60% + numpad keyboard  (Read 121451 times)
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
Re: [IC] 78 Key 60% + Numpad Keyboard
« Reply #50 on: Thu, 04 June 2015, 05:00:44 »
I'm going to need to start saving funds pronto. Are you guys working against any deadline?
Offline doodersbrother
« Reply #51 on: Thu, 04 June 2015, 20:21:13 »
No, but it should be finished very soon. The PCB is done and we are just polishing out the silkscreen and making sure the plate supports all the different layouts.
Offline VinnyCordeiro
« Reply #52 on: Fri, 05 June 2015, 08:15:23 »
Does anyone knows if Soarer's firmware supports backlighting? If not, then I'll have to start the PCB design from scratch, given some design limitations of tmk_keyboard. :(
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #53 on: Fri, 05 June 2015, 08:17:15 »
Hey Vinny.
Not good at this stuff, but does this: https://github.com/tmk/tmk_keyboard/issues/111 help you?
« Reply #54 on: Fri, 05 June 2015, 08:23:31 »
Hey Vinny.
hasu already linked that to me. My problem isn't with backlighting per se. It's about the maximum number of columns/rows the firmware support. The way tmk is structured it allows a 16x16 maximum matrix. This keyboard have 19 columns. That's why I'm asking about Soarer's firmware, because AFAIK it is agnostic to column/row number (as long as you have a keyboard with a maximum of 256 keys).
« Reply #55 on: Fri, 05 June 2015, 08:34:31 »
Nevermind, already found a solution for that. Just need to rearrange some columns and rows, but it'll work.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #56 on: Fri, 05 June 2015, 08:38:22 »
Awesome :)
Re: [IC] 78 Key 60% + Numpad Keyboard >NEEDS A NAME<
« Reply #57 on: Sat, 06 June 2015, 02:03:11 »
Any suggestions as to the name?
Offline radio_killah
  • Chinchillin'
« Reply #58 on: Sat, 06 June 2015, 02:13:48 »
- The Dooder
- "Right"hand man and "Left"hand man for whichever side your keypad is on
- Call one Brennan Huff and the other Dale Doback from "Stepbrothers"
- Dooder K01
- The brother board
- LXXVIII (78 in roman numerals)
Just a few crappy ideas lol
Offline Ngt
« Reply #59 on: Sat, 06 June 2015, 08:11:25 »
Really interesting. That's a pity I already started on a new project. Good luck with the group buys.:)
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« Reply #60 on: Sat, 06 June 2015, 12:02:40 »
I was thinking. If the pcb will be in two parts to support left and right arrangement. Will the plate also be in two parts and will the mounting holes in the case support this? Also need to consider the usb port placement. Would be freaking awesome if you could pull it off.
« Reply #61 on: Sat, 06 June 2015, 12:10:53 »
After some discussions and design checks, we decided to abandon the idea of separated boards and a single case for both versions: the gains are simply negligible to be worthy.
« Reply #62 on: Sun, 07 June 2015, 18:31:34 »
Just wanted to let you guys know the plate for the prototype is on the way! My plates are on the bottom right.
103007-0
103009-1
103011-2
Plates are made of steel and then sandblasted. Should be very solid  :thumb:
« Last Edit: Sun, 07 June 2015, 18:33:23 by doodersbrother »
Offline Seranite
  • Doesn't know what's going on.
« Reply #63 on: Mon, 08 June 2015, 09:15:17 »
Looks great! Much excite  :D
« Reply #64 on: Wed, 10 June 2015, 18:02:40 »
If you guys could fill out this poll it would be very appreciated. Thanks!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [IC] 78 Key 60% + Numpad Keyboard &gt;NEEDS A NAME&lt;
« Reply #65 on: Wed, 10 June 2015, 18:04:54 »
Eyy, I've got your plates :)
Offline Bull1919
« Reply #66 on: Wed, 10 June 2015, 21:03:27 »
You should name it the desktop truck, because it has a similar layout to the apple desktop bus keyboard, and it's built like a truck :P
Re: [IC] The TK78, a custom 78 Key 60% + numpad keyboard
« Reply #67 on: Thu, 11 June 2015, 21:50:16 »
Another update. We decided to omit the second USB port on the hub as we wouldn't have been able to get the ports to be flush with the case. So instead we used the space between the numberpad and alphanumeric part of the keyboard and only use one single USB port.
Offline simonyunhe
« Reply #68 on: Thu, 11 June 2015, 23:50:42 »
Good to know, looking forward to get the board.  ;D
KeyBs:|RS96-Brown|GS-87-White|DIYer60-Red|VA68M-Brown|GS-ALT71-Blue|IKBC-108-Black|
KeyCs:|SA Carbon R1+2|SA Camping|SA Amazing Chocolatier|SA Commando 88 Ghost|SA Hyperfuse|SA Penumbra|SA Doom|SA Creamy Orange|SA Ocean Dolch|SA Lotus*72|SA Trouble Minds R2|DSA Granite|GMK TA|GMK Soware|XDA Mailstone|GM Ember|
« Reply #69 on: Sun, 14 June 2015, 20:50:03 »
PCB completed!!
103475-0
« Reply #70 on: Sun, 14 June 2015, 21:17:03 »
PCB completed!!
The PCB core is ready, now I just have to finish the details, namely silkcreen legends.
Offline wlhlm
« Reply #71 on: Mon, 15 June 2015, 02:29:58 »
PCB completed!!
Looks good! Are you the designer behind the Planck PCB?
« Reply #72 on: Mon, 15 June 2015, 05:31:45 »
PCB completed!!
No, Jack made the design himself.
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #73 on: Mon, 15 June 2015, 06:17:23 »
PCB completed!!
No, that was actually me.  :D  https://geekhack.org/index.php?topic=70092
But the black PCB was definitely Jack's idea. I prefer red. Red goes faster.  ;D
« Reply #74 on: Mon, 15 June 2015, 06:29:43 »
PCB completed!!
Sorry, didn't know that.
This PCB will be matte black, which is fine. I myself prefer blue because it is cooler. :)
Offline okwchin
« Reply #75 on: Tue, 16 June 2015, 10:48:09 »
Wooo! looking good!
« Reply #76 on: Sat, 20 June 2015, 19:13:37 »
Plates came!
« Last Edit: Sat, 20 June 2015, 19:18:10 by doodersbrother »
Offline cryptowillem
« Reply #77 on: Sat, 20 June 2015, 19:18:19 »
Plates came!
Woohoo! It's awesome to see this project come together.
Got nothing for ya. Head back to camp.
Coolermaster Quickfire Rapid TK w Blues
WASD Code TKL w Greens
Offline simonyunhe
« Reply #78 on: Sat, 20 June 2015, 19:18:48 »
Plates came!
Great, so we have pcb+plate? Any info for the case?
« Reply #79 on: Sat, 20 June 2015, 19:30:08 »
Plates came!
It'll be quite a nice board when all the parts come!
Plates came!
Actually we have a PCB render. Right now we are just adding the finishing touches on both the PCB and case and then we'll start the prototype run for those two as well.
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« Reply #80 on: Sun, 21 June 2015, 12:53:53 »
But are those the final plates? That would make me a sad panda as they are very restricted. But then again I don't see any mounting holes either so are they just a prototype?
Offline lolpes
« Reply #81 on: Sun, 21 June 2015, 15:20:18 »
No mounting holes for the plate? :/
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #82 on: Sun, 21 June 2015, 15:30:04 »
Not final plates. Just prototypes. The final ones will support more layouts and will have mount holes.
« Reply #83 on: Sun, 21 June 2015, 18:00:14 »
No, it is not even close to the final revision.
I mean it's a prototype plate just to confirm the layout. The final plate will obviously have mounting holes....
Offline Invaderevan
« Reply #84 on: Sun, 21 June 2015, 18:10:04 »
Plates came!
Damn son. That is a beautiful looking board, color me interested when a buy gets started!
WTTF Ribbits, Ashen V2 MX, Bronins
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« Reply #85 on: Thu, 25 June 2015, 03:01:41 »
Are you still considering changes to the layout? Was thinking that if you offer more choices in terms of layout you could spark even bigger interest, like having it as customizable as the Lightsaver.
Offline simonyunhe
« Reply #86 on: Thu, 25 June 2015, 05:37:36 »
I guess people will happy to see the plate support such layout, correct me if I'm wrong.
Offline wlhlm
« Reply #87 on: Thu, 25 June 2015, 06:14:10 »
At least the PCB got you covered:
except for the numpad bottom row, but from the OP:
Instead of splitting up the 2u "0" key into two 1u keys for arrow keys, we decided to move the arrow keys up one row to make sure it retains a standard bottom row for keyset compatibility.
Offline stoic-lemon
« Reply #88 on: Fri, 26 June 2015, 06:36:18 »
Numpad on left = bought. Good luck with this.
« Reply #89 on: Fri, 26 June 2015, 06:42:08 »
Then start saving your money for the TK78-L. ;)
Offline simonyunhe
« Reply #90 on: Fri, 03 July 2015, 10:55:44 »
Any updata?
« Reply #91 on: Fri, 03 July 2015, 11:39:13 »
Any updata?
PCB is going to the 5th revision, as we discover errors, make corrections, add/remove features and make modifications due to other facts not electronics-related, like mounting slots positions.
This week is being quite difficult for me: I design only on my spare time, and my daily job is quite busy at the beginning of each month. Add to that a recent case of sleep dysfunction. Work is going slower than I'd like. :(
Offline simonyunhe
« Reply #92 on: Sat, 04 July 2015, 09:54:52 »
Any updata?
Thanks for the hard work! Take your time. Looking froward to see the finished keyboard.
« Reply #93 on: Wed, 08 July 2015, 16:13:35 »
Another quick update. Plate was finalized.
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« Reply #94 on: Wed, 08 July 2015, 17:43:12 »
Looking good! But won't return require PCB mounted stabs?
« Reply #95 on: Wed, 08 July 2015, 17:51:05 »
Yes, that's right. Universal plates have this side effect, but it is the price you pay when trying to reach a broader audience.
Offline Seranite
« Reply #96 on: Wed, 08 July 2015, 23:07:40 »
Looking great, excited for this. I may make it my work keyboard.  :D
« Reply #97 on: Wed, 08 July 2015, 23:42:19 »
Some updates: the PCB prototype is already being made, just waiting the fab house to send them. Then we'll start developing a basic firmware for it.
While the PCB isn't here, I already started designing the TK78-L, the version of this keyboard with numpad at the left side. In 30 minutes it is 80% ready, I just needed to redo the guidelines and group move the keys. Just need to redo some traces, now. I think it will be possible to use the same firmware on both keyboards, but cases will not be interchangeable.
Offline stoic-lemon
« Reply #98 on: Thu, 09 July 2015, 03:25:47 »
I'm so very hyped for this. Dare I say...end game keyboard?
Who am I kidding? :D
Offline neuronbasher
« Reply #99 on: Thu, 09 July 2015, 23:52:47 »
Very interested!
