Author Topic: [IC] The TK78, a custom 78 Key 60% + numpad keyboard  (Read 121449 times)
Offline doodersbrother
Re: [IC] The TK78, a custom 78 Key 60% + numpad keyboard
« Reply #100 on: Mon, 13 July 2015, 20:13:38 »
The parts for the prototype are slowly coming together. We should have an update with details on the final version of the plate and case in the coming days. The Group Buy for the board looks like it will be on the beginning of August.
Offline Ngt
« Reply #101 on: Tue, 14 July 2015, 06:28:14 »
Cool! Have you ever consider doing a version with an acrylic mid piece? Perhaps it would ask for a lot of changes on the case but I'm curious.
Offline stoic-lemon
« Reply #102 on: Tue, 14 July 2015, 07:17:35 »
That is excellent news.
Offline Seranite
  • Doesn't know what's going on.
« Reply #103 on: Tue, 14 July 2015, 12:57:42 »
+1 I am excited for this.
Offline wlhlm
« Reply #104 on: Tue, 14 July 2015, 15:16:35 »
How much power can you draw from the USB hub? I've heard that's an issue with the HHKB for example.
Offline VinnyCordeiro
« Reply #105 on: Tue, 14 July 2015, 15:53:58 »
Can't draw much here either. If the datasheets of the components are right, we are talking about 200mA maximum per port.
« Reply #106 on: Wed, 15 July 2015, 16:24:53 »
No, but the next board I am planning will have a small acrylic window of sorts on the back with an RGB LED.
Offline Ngt
« Reply #107 on: Wed, 15 July 2015, 17:07:21 »
Would it have the same layout?
« Reply #108 on: Wed, 15 July 2015, 17:32:41 »
No. It's still in the concept stage so we don't know if it's even going to be produced.
Offline Ngt
« Reply #109 on: Wed, 15 July 2015, 17:33:56 »
Fair enough.
Offline vistination
    • Store
« Reply #110 on: Thu, 16 July 2015, 13:44:00 »
 :eek:
« Last Edit: Thu, 16 July 2015, 13:46:14 by vistination »
TK78 maker
« Reply #111 on: Thu, 16 July 2015, 13:45:43 »
Another quick update!
I found places for sandblasting, laser cutting, anodizing, and milling that all offer very reasonable prices in the US. Which means that the entire board (except for PCB) will be made in the US for those people who care about this kind of stuff.
Offline Seranite
« Reply #112 on: Thu, 16 July 2015, 14:45:37 »
USA! USA!
« Reply #113 on: Fri, 17 July 2015, 14:13:09 »
Another update: Final revision of the plates have been ordered. One just sandblasted, and two sandblasted/anodized in neon blue and the standard gunmetal grey. Should be here in a week.
Offline stoic-lemon
« Reply #114 on: Fri, 17 July 2015, 23:16:21 »
Awww yis.
« Reply #115 on: Tue, 21 July 2015, 01:00:45 »
Large Update
PCB's
Just ordered the prototype PCB's. We had a bunch of problems trying to order prototype PCB's with assembly. The thing with assembly is that it's very expensive at small quantities, which prototyping tends to be in.  Instead, Vinicius changed the design to use 0805 SMD components instead and the non-QFN version of the Atmel processor which would allow me to assemble the PCB myself. This time the order is concrete so you won't be seeing another update saying we ordered the PCB prototypes ;D They should get here within a week.
Plates:
As I said above, I ordered the final version of the plate in various colors and finishes. Those should be here in about a week as well.
Cases:
The final touches are being made to the case. We can source the cases locally through machine shops so the case will be here within 3 or 4 days of the files being finalized.
A few other things:
I talked with Sprit and we agreed to make gold stabilizers a default on the board as well as give you the chance to buy some gold springs. Cherry switches will also be able to be purchased for 50 cents a switch with the TK78 kit.
I ordered the LED's, PCB components, Gaterons, and other parts for the final prototype. The base firmware is steadily being worked on and should be ready soon.
Prototype will be made within a week or two and the Group Buy will commence soon after
« Reply #116 on: Wed, 22 July 2015, 16:55:39 »
Components for Prototype PCB arrived!
Offline Ngt
« Reply #117 on: Thu, 23 July 2015, 01:36:05 »
Looking forward to see how everything goes together.
« Reply #118 on: Sat, 25 July 2015, 04:03:59 »
Plates have been anodized! They'll arrive by Monday.
Offline stoic-lemon
« Reply #119 on: Sat, 25 July 2015, 08:26:21 »
What kind of anodizing options are we getting? This is exciting stuff!
« Reply #120 on: Sat, 25 July 2015, 09:41:43 »
For the prototypes we will have gunmetal gray and turquoise, don't know about production run.
Offline Seranite
« Reply #121 on: Sat, 25 July 2015, 12:33:34 »
Two of my favorite colors  :eek:
If either of those make it in to the production run I'm going to have a hard time choosing.
Offline stoic-lemon
« Reply #122 on: Sun, 26 July 2015, 04:06:00 »
Me too.
« Reply #123 on: Mon, 27 July 2015, 14:12:08 »
PCB's and plates have both shipped. DHL says they'll be here Wednesday.
Case is about to be milled.
« Reply #124 on: Tue, 28 July 2015, 12:46:40 »
I've finished the firmware some days ago, but can only be sure that it works when the prototype is assembled and the firmware flashed.
Offline Ngt
« Reply #125 on: Tue, 28 July 2015, 17:12:13 »
Looking forward to hear about that. :)
Offline THSdrummer
  • HKP hunter. Need moar.
« Reply #126 on: Wed, 29 July 2015, 13:34:43 »
Just wanted to mention my interest in this board. It sounds like an ideal work board for me. Only thing that would make it better would be if a "delete" key was accessible without hitting an Fn key as well. I'd love to have a smaller keyboard with a number pad though.
Leopold FC660m  CM Stealth TKL
WTB: ^^ (O-Zone Bro V2), Drunk Skull, Oktoberfest, Laser/Poison/Woodland HKPs, G1 HKP Gas Masks
MY CLASSIFIEDS THREAD
« Reply #127 on: Wed, 29 July 2015, 13:41:48 »
We will be using TMK as the firmware and releasing the source code for this keyboard, so you are free to add a Delete key for yourself. :)
Offline mbrown559
« Reply #128 on: Wed, 29 July 2015, 14:57:06 »
Definitely interested if we can get a left number pad version
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #129 on: Wed, 29 July 2015, 14:57:37 »
It's coming later
« Reply #130 on: Wed, 29 July 2015, 16:41:16 »
It's coming later
The PCB design for the left side numpad version is finished, by the way. ;)
« Reply #131 on: Wed, 29 July 2015, 17:06:35 »
It's coming later
Jesus that PCB must look crazy, sooo many switch modules in such a small area.
Offline THSdrummer
« Reply #132 on: Thu, 30 July 2015, 08:08:14 »
I'm not super great with this sort of stuff, but sounds great! This could be my ideal work keyboard! I'm excited.
Thanks!  :D
« Reply #133 on: Thu, 30 July 2015, 08:19:30 »
Thanks!  :D
You and about 95% of mechanical keyboard enthusiasts. We are looking for an easy way to allow people to reprogram their keyboards, as editing source code isn't exactly an option for the majority. So far I have found an online source generator for other keyboards, would need someone to make a version for the TK78.
Offline THSdrummer
« Reply #134 on: Thu, 30 July 2015, 13:07:18 »
Thanks!  :D
Just after reading threads, it sounds like everyone can program and code except me. Good to know I'm not alone.
Thanks so much for putting so much work into this board and its functions. I'm drooling over the idea of saving desk space, without losing any functionality or productivity.  :p
« Reply #135 on: Thu, 30 July 2015, 19:30:34 »
PCB's and plates arrived!
https://imgur.com/a/6MxRD
I linked to imgur because that many embedded images would lag the page.
Offline stoic-lemon
« Reply #136 on: Fri, 31 July 2015, 00:44:42 »
They look great from here. Are you happy with them?
Offline mbrown559
« Reply #137 on: Fri, 31 July 2015, 12:48:47 »
It sounds like the left number pad PCB has been created.  Should we anticipate the left number pad version available in the first buy or at a later date?
« Reply #138 on: Fri, 31 July 2015, 13:00:10 »
I really don't know. At the moment we are debugging the prototype, both hardware and firmware. I already have a list of changes that must be done.
Offline mbrown559
« Reply #139 on: Fri, 31 July 2015, 13:31:29 »
Awesome, Thank you for the update and for all the hardwork on this project :).  Can't wait to see the final version.
« Reply #140 on: Fri, 31 July 2015, 14:04:20 »
Also, another exciting update. Since anodizing is so cheap from the manufacturer, the case and plate will have numerous colors available. You can also mix and choose. For example, a black case with a red plate, etc.
Offline lolpes
« Reply #141 on: Fri, 31 July 2015, 15:09:44 »
Hey could you put a keycap set on just to see the overrall look? :)
Offline lolpes
« Reply #142 on: Fri, 31 July 2015, 15:17:27 »
Also, what happened here? :/
« Reply #143 on: Fri, 31 July 2015, 15:24:04 »
Remember: this is a prototype. We are debugging the board, this kind of patch is common at this phase.
Offline lolpes
« Reply #144 on: Fri, 31 July 2015, 17:14:38 »
No prob ;) Happened to me before for bad sodering job :/
Offline Ngt
« Reply #145 on: Fri, 31 July 2015, 17:24:28 »
REally cool news! Are we still close to the price tag given in the OP or higher/lower?
Offline stoic-lemon
« Reply #146 on: Fri, 31 July 2015, 18:54:48 »
This just keeps getting better.
« Reply #147 on: Fri, 31 July 2015, 19:08:16 »
numpad on the left....
« Reply #148 on: Fri, 31 July 2015, 19:54:44 »
That would be the TK78-L (L indicating left hand  :p) which will launch on massdrop in the future.
Offline trenzafeeds
  • **** off
« Reply #149 on: Sat, 01 August 2015, 01:33:47 »
Oh wow I really want this. If you can keep it in the ~$250 range, I'm totally in.
demik will never leave.
Unless he gets banned.
