Author Topic: Hideous but interesting bizarro ALPS board with built-in speakers  (Read 3878 times)
Offline Matias
  • * Commercial Vendor
    • http://matias.ca
Odd and ugly beast with built-in speakers AND mechanical switches.  Not sure why exactly I'm posting this...  :-)
101979-0
101981-1
101983-2
101985-3
101987-4
101989-5
Offline Ludovician
Re: Hideous but interesting bizarro ALPS board with built-in speakers
« Reply #1 on: Fri, 29 May 2015, 06:00:34 »
Are those actually Alps switches? Never seen them before.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
« Reply #2 on: Fri, 29 May 2015, 08:50:38 »
Nope, it's not Alps. I forget the switch type, but it's not Alps.
Offline Snarfangel
« Reply #3 on: Fri, 29 May 2015, 09:19:47 »
Those speakers look like someone put Kinesis wrist pads on the wrong side. :)
Offline Touch_It
« Reply #4 on: Fri, 29 May 2015, 09:21:49 »
Those look pretty similar to Futaba switches, but the top housing looks different than ones I've seen.  Certainly looks to be mx compatible caps. Wonder how think they are.  I'm assuming thin pad printed ABS, but they look nice.
What I really would like to know though is how banging the sound is from the speakers.
Also Snarfangel you are spot on with that lol.  I can never un-see that now.
« Last Edit: Fri, 29 May 2015, 09:24:57 by Touch_It »
Offline esoomenona
  • Gnillort?
« Reply #5 on: Fri, 29 May 2015, 09:30:08 »
« Last Edit: Wed, 12 August 2015, 09:18:17 by esoomenona »
Offline Touch_It
« Reply #6 on: Fri, 29 May 2015, 10:06:18 »
Not at all. Opposite of MX, with stem being female as opposed to male.
I wonder if a Topre stem can be fitted in place of those stems. Look to be of similar size. Maybe a 101/103U could be fitting into this somehow?
You are right.  I'm to sleepy to be posting on the forums lol.  I even have a keyboard with the same type of keycap right by me :(.  Thx for the correction.
Offline ander
  • I type, therefore I am
« Reply #7 on: Fri, 29 May 2015, 22:50:06 »
And it's ISO, of course.
Offline jeb
« Reply #8 on: Mon, 01 June 2015, 08:38:07 »
It's ISO, in a US layout, with German control keys, and extra Cyrillic legends. Perfectly reasonable.
Offline Snarfangel
« Reply #9 on: Mon, 01 June 2015, 09:11:55 »
Offline datacenter
« Reply #10 on: Fri, 05 June 2015, 10:24:22 »
Guys, do you have a clue about the switches. I might be able to buy one, but I am unable to find any info :(
To me it looks like rubber dome ... but?
