Author Topic: Case for Phantom  (Read 1245 times)
Offline nova779
Case for Phantom
« on: Fri, 29 May 2015, 14:12:18 »
I am nearing completion of my phantom and I was wondering what cases I could use to put it in, I don't mind having to modify the case slightly as long as it doesn't effect the outer appearance, but can anyone name some brands that aren't too expensive?
Re: Case for Phantom
« Reply #1 on: Fri, 29 May 2015, 14:19:52 »
The phantom was designed to fit in a filco case but a QFR case can also be modified so it will fit. Sadly no one has came out with good phantom cases lately, there have been a few failed attempts along the way but nothing consistent.
Some people use a makeshift cardboard case and you might be able to get some acrylic and use some spacers to make a makeshift bottom to screw it into somehow, but IIRC holes for screws in the phantom itself are limited.
