Author Topic: 40% 4x13  (Read 3954 times)
Offline mecano
40% 4x13
« on: Fri, 29 May 2015, 17:50:23 »
Hello,
I'm planning on building this :
102047-0
I would have save some and get a planck but I can't get the 12 columns design, every qwerty build of it I saw cut one or more alpha key to get modifiers on the left, right or both.
I came to the conclusion that to preserve the qwerty you had to add 1 column.
I suspected some firmware/chips/matrix limitation for nobody taking such an obvious way but how could it be? If we can have 4x12 or 5x15, 4x13 should be fine.
Still, maybe I am overlooking something? What do you think?
« Last Edit: Sat, 30 May 2015, 03:06:04 by mecano »
Offline NoahBC
Re: 40% 4x13
« Reply #1 on: Sat, 30 May 2015, 22:02:35 »
I'm unclear on the problem you're trying to solve here.
I'm typing on a planck right now, and all my alpha keys are where they would be on any other keyboard, aside from being in a matrix.
Offline mecano
Re: 40% 4x13
« Reply #2 on: Sun, 31 May 2015, 03:00:35 »
Hello Noah,
by alphas I mean alphas and signs commonly included within (maybe I'm not using the right term?).
Problem is a lot of people are using control/modifiers/tab on the left, doing this you have to sacrifice the last "alpha" column on the right, if not cutting off two "alphas".
102151-0102153-1
I want to preserve the brackets and have modifiers on the left as on the picture in first post.
How do you deal with brackets and such yourself?
Offline vivalarevolución
Re: 40% 4x13
« Reply #3 on: Sun, 31 May 2015, 08:22:00 »
On my Planck, I put the brackets, semicolon, and pipe/backslash on the function layer.  Everything else is on the first layer.  Considering that I use these symbols infrequently, it is not much of a problem.  But I guess that it comes down to what you prefer.
Offline mecano
Re: 40% 4x13
« Reply #4 on: Sun, 31 May 2015, 14:03:18 »
Hello viva,
thanks for joining in.
I could live without direct access to pipe and backslash as I come from azerty but brackets would be a turn back.
How do you deal with the equal and addition signs? Curious about this.
Otherwise, I met a metal worker this week end, he'll may work on a custom case (forming/bending and brazing).
Offline hoz
  • 60% is more than enough.
Re: 40% 4x13
« Reply #5 on: Sun, 31 May 2015, 22:54:27 »
uhm, im pretty sure you will find having enter, backspace, esc and tab within an fn-layer far more inconvenient than brackets...
one 40% and seven 60%'s
Offline RoastPotatoes
    • RoastPotatoes Keyboard Blog
Re: 40% 4x13
« Reply #6 on: Sun, 31 May 2015, 23:08:58 »
This is an excellent idea. Those other keys were just holding you back.
Offline mecano
Re: 40% 4x13
« Reply #7 on: Mon, 01 June 2015, 02:44:21 »
In fact I'm using this layout on my Pure Pro at the moment.
The enter, esc, backspace and tab are on the control layer and are the more convenient things I have tested so far!
What do you mean Roast?
Re: 40% 4x13
« Reply #8 on: Mon, 01 June 2015, 02:47:48 »
It's like the HHKB layout. I don't use the bottom right and bottom left keys so they don't exist. You seem to be taking this a little further.
Offline mecano
Re: 40% 4x13
« Reply #9 on: Mon, 01 June 2015, 03:15:06 »
Oh yes!  :D
Still wondering if not putting keys there is a good idea though, there is the estate why not use it? But putting keys I'll use twice a year…
Maybe putting a tracking device on the right?
Right now on the Pure I have a mouse mode with jkl; moving down up left down, I don't use it very often though, I must add diagonals.
Offline mecano
Re: 40% 4x13
« Reply #10 on: Mon, 01 June 2015, 04:07:48 »
I better understand your "holding back", Roast, if you put functionality there, you won't put it elsewhere and as it has poor accessibility…
I'll leave it as is.
