Author Topic: [IC] Dihedral 79 Plates - Now with keycap prices - GB Thread coming Soon  (Read 37940 times)
Offline Dihedral
  • Mostly Harmless
Dihedral 79 Plate Interest Check
Original Post
Please Complete This Form If Interested
The Dihedral 79 is a board I have been working on for a long time as my endgame - a board that is small but also does not compromise on any usability. Above you can see an image of it's layout - which employs an Merged Ten Key design whereby the numpad and navigation block are merged together in a way similar to that seen on the CM Storm TK
Taken from my original thread:
Based on a TKL design, the D-79 puts the f-keys behind a function layer to create a slim and attractive keyboard, while merging the num-pad into the navigation cluster to enable fast number input without a full-size keyboard. The D-79 also maintains the dedicated arrow keys that make the TKL format so attractive to many users, and splits the spacebar into two to minimise space wastage and to create a better positioned backspace.
This is an IC for a Dihedral 79 Plate group buy - a planned GB which will allow anyone interested in this design to get a plate and build a board based on it.
Base Offering
D-79 Plate in 1.5mm Stainless Steel.
Hopefully can also be included in base package
Two 2.5u DCS bars with each plate purchased.
Potential Extra Offerings
Acrylic Layered Case as an extra option for the GB.
« Last Edit: Mon, 13 July 2015, 13:18:16 by Dihedral »
Offline rm-rf
Re: [IC] Dihedral 79 Plates
« Reply #1 on: Sat, 30 May 2015, 12:42:32 »
this is a posting for my interest.
Offline Bull1919
« Reply #2 on: Sat, 30 May 2015, 12:45:34 »
That 2.5u spacebar is gonna be really difficult to find
Also, no backspace?
« Last Edit: Wed, 19 August 2015, 20:22:41 by Bull1919 »
Offline cmadrid
« Reply #3 on: Sat, 30 May 2015, 12:47:17 »
I understand the idea behind the spacebar, but I don't like it >_<
Offline wakko
« Reply #4 on: Sat, 30 May 2015, 12:48:23 »
Interested
NOOB
KUL ES-87
Offline Dihedral
  • Mostly Harmless
« Reply #5 on: Sat, 30 May 2015, 12:49:50 »
Also, no backspace?
 It's the left 2.5 bar. SP can make them.
Offline Dihedral
  • Mostly Harmless
« Reply #6 on: Sat, 30 May 2015, 12:51:36 »
There is currently another IC for a standard space bar board run by doodersbrothers.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #7 on: Sat, 30 May 2015, 13:07:07 »
Original Post
Base Offering
What kind of case would you offer with it ? Sandwhich case with SwillKB's builder?
I think it looks cool :)
Offline Bull1919
« Reply #8 on: Sat, 30 May 2015, 16:09:57 »
Also, no backspace?
In just saying, it makes the aftermarket options very limited
Offline livingspeedbump
    • KeyChatter
« Reply #9 on: Sat, 30 May 2015, 17:06:15 »
Very cool, definitely going to be following this thread. I'm definitely interested.
<- My Collection (so far)
Offline wakko
« Reply #10 on: Sat, 30 May 2015, 17:48:31 »
+1 for an acrylic sandwich case
NOOB
KUL ES-87
Offline Dihedral
  • Mostly Harmless
« Reply #11 on: Sun, 31 May 2015, 04:39:49 »
Original Post
Base Offering
Yeah, that kind of thing.
Offline Dihedral
  • Mostly Harmless
« Reply #12 on: Sun, 31 May 2015, 04:43:59 »
Also, no backspace?
Any split spacebar design excluding 1u makes aftermarket hard. This design keeps standard mods and also includes a 1.5u function key in the middle. I think that plain black 2.5u bars will not look out of place with most SP sets. There could be an option for black or white bars with your board.
Offline Dihedral
  • Mostly Harmless
« Reply #13 on: Sun, 31 May 2015, 13:08:35 »
Bump
Offline Dihedral
  • Mostly Harmless
Re: [IC] Dihedral 79 Plates - PLEASE COMPLETE FORM IF INTERESTED
« Reply #14 on: Mon, 08 June 2015, 10:01:11 »
If you're interested, please complete the form linked above.
Offline rm-rf
« Reply #15 on: Mon, 15 June 2015, 08:49:23 »
filled out the form!
Offline Dihedral
  • Mostly Harmless
« Reply #16 on: Fri, 19 June 2015, 13:43:54 »
Great thankyou.
Offline wakko
« Reply #17 on: Fri, 19 June 2015, 23:18:39 »
Filled out  the form
NOOB
KUL ES-87
Offline Dihedral
  • Mostly Harmless
« Reply #18 on: Sat, 20 June 2015, 01:07:15 »
Filled out  the form
Great thanks
Offline rm-rf
« Reply #19 on: Sat, 20 June 2015, 01:19:16 »
i hope this thread builds up more interest, i want to make one of these!
Offline Dihedral
  • Mostly Harmless
« Reply #20 on: Sat, 20 June 2015, 03:04:08 »
There has been some interest so I hope it will be able to go ahead :)
Offline Dihedral
  • Mostly Harmless
« Reply #21 on: Sat, 11 July 2015, 03:23:38 »
Bump
Offline Dihedral
  • Mostly Harmless
Re: [IC] Dihedral 79 Plates - Now with keycap prices.
« Reply #22 on: Mon, 13 July 2015, 13:17:39 »
Update - It appears that we will be able to sell the Keycap kit for around 10 dollars a pair, excluding shipping.
Offline diqkiq
Interested. I filled out the forrm
Filco Majestouch TKL, Noppoo Choc Mini, Realforce 87 55g, Model M TKL, Ducky Shine 3 TKL, KC60, Planck.
Offline notmybongos
Re: [IC] Dihedral 79 Plates - Now with keycap prices - GB Thread coming Soon
« Reply #24 on: Mon, 20 March 2017, 20:59:10 »
Would it be possible to flip this plate and have a left-hand numpad? Or is it cut in a way that requires switch installation from one side?
I can't imagine I just came up with a revolutionary idea in plate design . . .
 :rolleyes:
Offline iFreilicht
« Reply #25 on: Tue, 21 March 2017, 08:02:08 »
 :rolleyes:
The problem is that the stagger isn't uniform. Your idea is pretty cool, but it would only work with a uniform .5u stagger.
Sentraq S60-X, dyed blank PBT keycaps, Gateron Browns
