Author Topic: Dihedral 79 (80% Merged Ten Key board)  (Read 67952 times)
Offline Dihedral
  • Mostly Harmless
« on: Thu, 22 January 2015, 13:29:42 »
Dihedral 79
The Dihedral 79 is my optimum keyboard; removing the keys I don't need, and retaining those that I do; creating a compact keyboard that doesn't sacrifice usability while maintaining a minimal impact on desk space.
Based on a TKL design, the D-79 puts the f-keys behind a function layer to create a slim and attractive keyboard, while merging the num-pad into the navigation cluster to enable fast number input without a full-size keyboard. The D-79 also maintains the dedicated arrow keys that make the TKL format so attractive to many users, and splits the spacebar into two to minimise space wastage and to create a better positioned backspace.
If you are interested in seeing this board produced commercially or want to submit an idea or feedback, please don't hesitate to post here.
Progress so Far
  • Design finalised (Thanks to ijprest's keyboard-layout-editor tool)
  • Have plate designs (Thanks to jdcarpe for generously creating the .dxf files.)
  • Have a quote for a plate, but would prefer to buy a few and sell some on. If you want a plate, please post in this thread.
Plate image:
Next Steps
  • Get preliminary plates cut.
  • Work out how case will be built: potentially an acrylic one like Matt3o's 'fox' custom keyboards.
Links
Credits
ijprest for his keyboard-layout-editor
jdcarpe for creating the plate files
« Last Edit: Fri, 19 August 2016, 17:51:08 by Dihedral »
Offline vordep
Re: Dihedral 79 (80% Merged Ten Key board)
« Reply #1 on: Sun, 25 January 2015, 08:54:52 »
You could use the " other guy plate building tool" , ive already used it on my layoutits not user-friendly but it will work fairly well
Offline dimmu
« Reply #2 on: Sun, 25 January 2015, 09:04:23 »
this might be asking for too much but i would prefer a version where the numpad is located on the leftside of the keyboard instead.
Offline azhdar
  • Praise the AZERTY god
« Reply #3 on: Sun, 25 January 2015, 09:06:18 »
Interesting layout , have you considered replacing the delete key with Fn and putting the Delete on the Fn layer of the Backspace ?
Azerty Propagandiste
Offline vordep
« Reply #4 on: Sun, 25 January 2015, 09:29:45 »
like this ? http://www.keyboard-layout-editor.com/#/layouts/c09efc02bfa6973fd4194408494f4784
Offline Liar
« Reply #5 on: Sun, 25 January 2015, 09:37:47 »
Agreed 100%
Block on left side would be fantastic
« Reply #6 on: Sun, 25 January 2015, 09:40:35 »
Reminds me a bit of TheFlyingRaccoon's LongCat Project.
Good luck with your build! Find your plate drawing attached. :)
Offline Dihedral
  • Mostly Harmless
« Reply #7 on: Sun, 25 January 2015, 09:49:28 »
Not at all. I was already planning to try that.
Offline Dihedral
  • Mostly Harmless
« Reply #8 on: Sun, 25 January 2015, 09:50:11 »
I am speechless. Thanks so much!
« Reply #9 on: Sun, 25 January 2015, 09:56:05 »
You're welcome! :D
If you need something changed, just PM me.
Oh, and here's one with the numpad on the left...
Offline Dihedral
  • Mostly Harmless
« Reply #10 on: Sun, 25 January 2015, 10:09:29 »
You're welcome! :D
Great! I'll make sure to credit you in the OP.
Offline Dihedral
  • Mostly Harmless
« Reply #11 on: Sun, 25 January 2015, 10:19:58 »
Not personally, as I use delete quite frequently and that would feel like an awkward place for Fn. The board will use a teensy though, so will be re-programmable.
Offline derezzed
« Reply #12 on: Thu, 29 January 2015, 23:22:22 »
It looks like there's a rising trend in split space bar designs lately.  I love it.    This is one of the best layouts I've seen yet.
Things I like:
     re-purposed the traditional backspace key to the num pad key
     delete key in a more accessible location (may require an adjustment period to retrain fingers to avoid hitting delete when trying to hit space or backspace)
     TKL form factor that retains the num pad!
     of course, backspace key for left thumb (suck it, full-length space bar!)
Minor complaint that is not specific to your design:  Standard-sized shift keys seem like such a waste of real estate.   I know why the size of the right shift key is optimal for standard 80% and up layouts but it still bothers me.   It seems like the left shift could be safely split into 2 keys, with the left-most key becoming scroll lock [with your design (there's no need for a second scroll lock on keyboards that already have one)] or some other modifier.
I am eager to see this keyboard get made.  The more I look at it, the more I like it.
Offline Dihedral
  • Mostly Harmless
« Reply #13 on: Fri, 30 January 2015, 01:49:41 »
Things I like:
Thanks for the feedback! I agree about the shift but begrugingly kept it so it will be easier to find keycaps.
Offline Dihedral
  • Mostly Harmless
« Reply #14 on: Fri, 06 February 2015, 12:44:55 »
Anyone interested in a Dihedral 79 plate? Even if just a few people go for it it could push price down a fair bit.
« Reply #15 on: Fri, 06 February 2015, 14:11:02 »
Are you planning on making a PCB for it? Or is this going to be strictly hand wired?
Offline Dihedral
  • Mostly Harmless
« Reply #16 on: Fri, 06 February 2015, 15:17:41 »
i'm going to handwire, though if someone wanted to design a pcb i would be totally happy with that.
« Reply #17 on: Fri, 06 February 2015, 15:24:24 »
The only reason I ask it that, I would definitely be interested, if only it supported some other layout options in the same form factor. I don't know that I could live with that spacebar arrangement, for instance, or I might like to have a 2-unit backspace, or a 1.75-unit right shift, etc. I could design you a plate that would cover those options, but the stabilizer holes wouldn't support plate mounting anymore, hence the necessity of a PCB.
Offline Dihedral
  • Mostly Harmless
« Reply #18 on: Fri, 06 February 2015, 15:33:25 »
If you want to build an alternate design i would be happy to add it into the OP. However, the point of my original post wasnt to start a massive group buy, just to see if it would be worthwhile getting five or ten plates instead of just one. This is still, in my mind, a small project so I can build my endgame board.
« Reply #19 on: Fri, 06 February 2015, 15:35:17 »
Yep, understood. It's a good project!
Offline Dihedral
  • Mostly Harmless
« Reply #20 on: Fri, 06 February 2015, 15:37:03 »
thanks for the support. sorry if my post came off as rude, im kind of tired and finding it hard to string words together :)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #21 on: Fri, 06 February 2015, 15:57:51 »
Just wondering, but is the split space bar setup possible on the Phantom?  Or did it not have those switch locations?  I know the numpad area can be done on the phantom, aka "7bit" layout.
« Reply #22 on: Sat, 07 February 2015, 11:03:45 »
Sorry for the OT, Dihedral, but I just want to quickly answer Melvang's question. The Phantom could not support the same bottom row as OP's design, because the switch locations for those keys are not present on the PCB. the closest thing with a split spacebar I could come up with for the Phantom is this: 1.25-1.25-1.25-2.00-1.00-1.50-1.00-2.00-1.25-1.25-1.25. That would require a custom plate to be made. :)
Didn't sound rude to me. :D
« Last Edit: Sat, 07 February 2015, 11:05:26 by jdcarpe »
Offline Dihedral
  • Mostly Harmless
« Reply #23 on: Sat, 07 February 2015, 11:38:53 »
One other subtle difference is the lack of a 2u backspace, which phantom presumably does not support.
« Reply #24 on: Sat, 07 February 2015, 12:16:17 »
The Phantom actually does support either a 2u key or 1u-1u keys in the backspace position. Again, plate dependent. :)
Offline Dihedral
  • Mostly Harmless
« Reply #25 on: Sat, 07 February 2015, 12:26:45 »
TIL!
Also, updated OP
« Reply #26 on: Sat, 07 February 2015, 15:51:33 »
I see that the layout has two 2.5u keys in the bottom row for the Backspace and Space. That size of keycaps could be difficult to source.
Let me suggest 2.25 for Backspace and 2.75 for Space so that you can use the same keycap as left and right Shift. That would also put Delete a tiny bit closer to the left thumb.
Offline Dihedral
  • Mostly Harmless
« Reply #27 on: Sun, 08 February 2015, 02:49:01 »
I can deal with sourcing the keys, but if the key size on the bottom row was asymmetrical it would look pretty awful.
Offline brimborion
  • Likes Matias Switches
« Reply #28 on: Mon, 09 February 2015, 02:29:39 »
This is pretty neat.
For me, the problems I would maybe have; sometimes I hit backspace rapidly and my left thumb isn't as good for that as my right. Also, where the keypad enter is, mis-keying it when using the cursors would be more catastrophic than a key that doesn't say, submit a form or send an email.
Buckling Spring: 42H1292,  1391401, Unicomp Linux 101, Customizer 104 | Cherry Blue: Rosewill RK-9000, Das Keyboard S Pro | Cherry Black: Wyse/Link 840358-30| Rubber Dome: various Key Tronic, HHKB Lite, HHKB Lite 2, KB-8923, 71G4644 | Topre: Type Heaven | ALPS: Matias Mini Tactile Pro, 2xKBP V60
Offline Dihedral
  • Mostly Harmless
« Reply #29 on: Mon, 09 February 2015, 10:38:01 »
That's understandable, but I pretty much never mis-hit the arrow keys so this is essentially a non issue for me. I think the speed reduction in using left thumb is negated by the speed increase in not having to move your hands from the home row - which I much prefer as a feature.
Offline kulaan
« Reply #30 on: Thu, 12 February 2015, 13:54:52 »
This is a pretty awesome layout. I can totally imagine myself using this. Just one question.
What is the function of the Num Lock key? I was under the impression the Nav Keys are under a function layer. Is it a Nav cluster until num lock is on? At which point the nav cluster is now under a function layer?
Offline Dihedral
  • Mostly Harmless
« Reply #31 on: Fri, 13 February 2015, 11:38:19 »
Yep, nav cluster unless num lock is on.
Offline Dihedral
  • Mostly Harmless
« Reply #32 on: Fri, 13 February 2015, 11:39:14 »
Oh, and welcome to GeekHack!
Offline kulaan
« Reply #33 on: Wed, 18 February 2015, 14:18:45 »
Where would I be able to source 2.5 sized keys for Backspace and Spacebar?
Offline Dihedral
  • Mostly Harmless
« Reply #34 on: Wed, 18 February 2015, 14:59:11 »
I think WASD will be our best bet.
Offline Melvang
« Reply #35 on: Wed, 18 February 2015, 15:31:47 »
2.5 unit is available from SP in SA and DCS profiles only and only in Row 4 but not space bar profile.
The shortest keys available in space bar profile is 4 unit in DSA and 4.5 unit in DCS.
http://www.keycapsdirect.com/pdfs/SAFamily.pdf
http://www.keycapsdirect.com/pdfs/DCSFamily.pdf
Again, SP does not have a mold for 2.5 unit in DSA.  The cheapest price I think I have heard for a new mold for SP is 3,000USD.
http://www.keycapsdirect.com/pdfs/DSAFamily.pdf
Offline Dihedral
  • Mostly Harmless
« Reply #36 on: Thu, 19 February 2015, 02:07:37 »
DCS Row 4 looks like it would work perfectly well.
Offline thebornotaku
« Reply #37 on: Sun, 01 March 2015, 03:00:16 »
derp, mispost.
Daskeyboard Professional MX Browns, the work board.
Daskeyboard Professional MX Blues, the clicky temporary board.
CM Storm Quickfire PRO MX Browns, the broken home board out for RMA.
Offline Dihedral
  • Mostly Harmless
« Reply #38 on: Sun, 01 March 2015, 10:33:50 »
derp, mispost.
Thanks for the thread publicity :P
Offline stoic-lemon
« Reply #39 on: Tue, 03 March 2015, 03:19:31 »
This a really interesting project. I'm afraid I have nothing to offer but my wallet. I would really need some kind of case for it though.
Offline Dihedral
  • Mostly Harmless
« Reply #40 on: Tue, 03 March 2015, 10:26:33 »
Thanks for your support. Personally, I'm probably going to make a wooden case. If this gets successful then maybe some kind of group buy will be in order :)
Offline regack
« Reply #41 on: Tue, 03 March 2015, 20:07:48 »
It's been a while since I was last here and poked at some projects, but this should work, and you can use this as a starting place.  I did change your 2.5 keys into 2.75 and adjusted the 1.25 down to 1.0 in order to make it easier.  I didn't even know there were 2.5 keys.  I know that's not what you wanted, but I've attached all the relevant files so you can make adjustments. :D
92676-0
This should demonstrate how it could be built with the matrix provided.  It's not the cleanest, the matrix is not exactly clean, since I jammed things in where there wasn't space... I was working from another project I was dabbling with a long time ago, and I just adjusted it really quick to be closer to your layout.  There is an LED under CAPS and the center key/spacebar to use as... an indicator? Technically there is still one pin free on the atmega.
92678-1
Edit: I removed the zip file, because I realized that the diode footprints are old and wrong - I'll update it and post a new file back in.
Edit2: see this post for the updated zip file.
« Last Edit: Wed, 04 March 2015, 08:41:14 by regack »
Offline Dihedral
  • Mostly Harmless
« Reply #42 on: Wed, 04 March 2015, 01:56:29 »
This is great! Thank you! I poked into pcb design but was overwhelmed. What software should I use to adjust the design?
Offline stoic-lemon
« Reply #43 on: Wed, 04 March 2015, 04:03:26 »
Interest intensifies.
Offline regack
« Reply #44 on: Wed, 04 March 2015, 08:39:41 »
This was all done in KiCad - Build 2013-02-13 BZR 3947.
I fixed all the diode footprints in this version :
« Reply #45 on: Wed, 04 March 2015, 08:41:00 »
Good to see you around regack! Hope life is treating you well. :D
Offline SL89
« Reply #46 on: Wed, 04 March 2015, 09:03:24 »
I totally forgot about this thread, i'm glad to see this moving on, i saw a similar layout a while ago but this one looks the most compelling. i usually favor the standard spacebar, but after thinking about it i can see why some people would enjoy this, and i think i'd like to give it a whirl at some point. Either way, thanks for working on this, projects like this are always very interesting.
« Reply #47 on: Wed, 04 March 2015, 09:16:45 »
Wow, has it really been two years?!
Welcome back, regack! We've missed you. :)
Offline Dihedral
  • Mostly Harmless
« Reply #48 on: Wed, 04 March 2015, 09:41:11 »
Thanks for your support. It's good to see people taking an interest in it.
Offline regack
« Reply #49 on: Wed, 04 March 2015, 19:55:42 »
Well, I know nobody asked for this... but...
92777-0
... I thought I would try re-doing it for Cherry MX + Alps
(it's an addiction)
