Author Topic: The LongCat Project  (Read 21795 times)
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
The LongCat Project
« on: Tue, 21 May 2013, 20:18:58 »
It started out as a crazy idea in IRC to build a 40% keyboard with a tenkey. However though the information in this thread ( http://geekhack.org/index.php?topic=40567.0 ) I decided to attempt to build said keyboard. I would like to give a shoutout to CPTBadAss for helping me with this project so far and Flip for naming it. Also metalliqaz for inspiring me with his awesome Epsilon case design.  I thought I would share my progress here.
Planned layout
Plate just cut on CNC mill
Switches and standoffs installed
Keycaps on
Lots of soldering to do!
Backplate and feet attached
Teensy attached to backplate
Left to do:
-Wire up the matrix/ solder switches
-Program the Teensy
« Last Edit: Thu, 23 May 2013, 16:38:43 by TheFlyingRaccoon »
HHKB Pro 2   SmallFry Keyboard
Re: The LongCat Project
« Reply #1 on: Tue, 21 May 2013, 20:20:39 »
Wow that board came out really nice. I thought you said that the plate came out ****ty but it looks really good here. Are you just going to keep it a skeleton like that or are you making a case as well? And thanks for the shoutout! I'm not sure how much I help but I'm glad you feel that I did ^__^
« Reply #2 on: Tue, 21 May 2013, 20:21:00 »
This is so cool, keep up the innovation and pushing the limits of keyboard layouts!!
Offline SmallFry
« Reply #3 on: Tue, 21 May 2013, 20:23:30 »
SWEET!
Offline inteli722
« Reply #4 on: Tue, 21 May 2013, 20:26:00 »
This looks awesome!
Have a free llama!
:llama:
Waiting for: Phantom Plate
« Reply #5 on: Tue, 21 May 2013, 20:39:48 »
Looking great! I'm kinda jealous, but it's awesome that you took your idea and ran with it. :D
« Reply #6 on: Tue, 21 May 2013, 21:28:11 »
wow that was fast dude.  Looking good.
Offline codyeatworld
« Reply #7 on: Tue, 21 May 2013, 21:31:07 »
I wouldof donated those caps to you if I knew you were gonna do this!
Can't wait for more, I like the layout design!
  • HHKB Pro
« Reply #8 on: Tue, 21 May 2013, 21:37:02 »
Thanks for all the support and kind words.  ;) I don't think I could have built this without all you great geekhackers providing me with the materials and knowledge to do this.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #9 on: Tue, 21 May 2013, 21:51:11 »
looks good :)
Offline regicide
  • Software developer and Open source hacker
« Reply #10 on: Wed, 22 May 2013, 02:51:25 »
Seriously awesome stuff, is the 'plate' made from acrylic?
I actually quite like the layout too!
2 Kinesis advantages (MX browns)
Offline dko2o
« Reply #11 on: Wed, 22 May 2013, 03:01:22 »
Wow that is pretty cool layout, was exactly what i was looking for (what i was asking samkoiwse in his thread).
Just wondering are you left handed? I know it isn't mounted to a pcb yet but how do u find having the keypad to the left?
Offline Paranoid
« Reply #12 on: Wed, 22 May 2013, 05:31:18 »
That's cool man :) how thick is the plate? Does it feel sturdy?
« Reply #13 on: Wed, 22 May 2013, 05:34:46 »
I think I already said this in IRC but : This is a cool idea for a layout, and your ideas case-wise have been fresh and unique. I'm glad you made this happen and it looks awesome so far. I can't wait to see the finished result.
  • HHKB Pro
« Reply #14 on: Wed, 22 May 2013, 08:37:16 »
The plate is 1/16" polycarbonate I ordered from Mcmaster. It is pretty sturdy although I'm sure aluminum would be better.
I am right handed but I decided to put the tenkey on the left for numerous reasons.
-For gaming I can hit the number keys with my pinky
-My tenkey speed is about the same on both hands
-I prefer my mouse to be as close to the home row to minimize movement
-I can use the mouse and tenkey at the same time
« Last Edit: Wed, 22 May 2013, 08:38:53 by TheFlyingRaccoon »
« Reply #15 on: Wed, 22 May 2013, 08:56:55 »
I can say from experience that acrylic in that thickness is not strong enough by itself, at least not for daily use.
« Reply #16 on: Wed, 22 May 2013, 08:57:49 »
I completely agree with all of this
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #17 on: Wed, 22 May 2013, 23:36:29 »
where's the longcat key bro?
Offline jonnybastard
« Reply #18 on: Wed, 22 May 2013, 23:50:32 »
That layout is very cool, nicely done sir!
KMAC    -    HHKB Type-S    -    Filco TKL LineaR    -    Poker X    -    KBT Race LE
flickr
Offline Dianoda
« Reply #19 on: Wed, 22 May 2013, 23:52:54 »
Custom dye-subbed 10x spacebar in the works?
  • HHKB Pro
« Reply #20 on: Thu, 23 May 2013, 16:39:32 »
Got the backplate cut out today. Updated OP
Offline SmallFry
« Reply #21 on: Thu, 23 May 2013, 17:51:51 »
That foot design is very cool. Props to ya.
Offline 4LI4Z
« Reply #22 on: Thu, 23 May 2013, 17:58:39 »
Very nice design, I like the idea of the Numpad at the right side.
BLING BLING GOLD SPRING
ErgoClear Filco MJT2 TKL || Apple EK II || Hall Effect Keypad || Cherry G81 HAD || IBM M SSK
  • HHKB Pro
« Reply #23 on: Mon, 24 June 2013, 21:00:05 »
Got my new lasered acrylic plates! One was broken but Pololu is sending me a new one free of charge which is pretty cool of them.
Also got some PBT beige Cherry keycaps which look pretty baller.
The spacebar doesn't fit so that will take some work but everything else looks good.
Working on the led wiring as of now and will post pictures when that is done.
« Reply #24 on: Mon, 24 June 2013, 21:01:44 »
If you're putty modding the spacebar, can you let me know what putty you're using? I want to do the same for my Leopold spacebar.
  • HHKB Pro
« Reply #25 on: Mon, 24 June 2013, 21:08:49 »
I actually 3D printed stems with supports between them. My plan is to dremel out the existing stems and supports and superglue the 3D printed one with the correct stem placement in.
« Reply #26 on: Mon, 24 June 2013, 21:16:05 »
No one likes a show off TheFlyingRaccoon! Just kidding. Take lots of pics of your custom swag :D
Offline mtl
« Reply #27 on: Mon, 24 June 2013, 21:26:21 »
Very nice!
MX13 SpaceSaver | Phantom | Tactoblack Filco -10 | Realforce 103U-UW | Variable Clicky Deck 82 | Deck Legend
« Reply #28 on: Mon, 24 June 2013, 21:27:57 »
Please make a build log, and show us how you wire this. :)
  • HHKB Pro
« Reply #29 on: Mon, 24 June 2013, 21:35:04 »
Very nice!
Thank you!
Oh I have some things up my sleeve  ;)
« Reply #30 on: Tue, 25 June 2013, 10:13:07 »
Nice! Apart from the plate breaking in shipping, were there any other problems with Polulu?
  • HHKB Pro
« Reply #31 on: Tue, 25 June 2013, 22:55:32 »
Nice! Apart from the plate breaking in shipping, were there any other problems with Pololu?
Nope, very fast shipping and great customer service! And they sent me a replacement plate yesterday. Also their prices were cheaper than any other service. I highly recommend them.
  • HHKB Pro
« Reply #32 on: Sun, 11 August 2013, 00:51:10 »
Finally some progress!
  • Modded all the switch covers so I can open up the switches without desoldering the LEDs
  • Changed up the switches. They used to be browns but now they all have black springs and a mixture of black and clear stems. Lubed the switches while I was at it
  • Got the first row of LEDs wired up. Only three more rows to go!
« Reply #33 on: Sun, 11 August 2013, 00:51:40 »
Awesome!!!
« Reply #34 on: Sun, 11 August 2013, 11:37:43 »
That's so fetch
  • HHKB Pro
« Reply #35 on: Sun, 11 August 2013, 11:43:24 »
  • HHKB Pro
« Reply #36 on: Mon, 12 August 2013, 16:28:02 »
I ordered 50 LEDs when there are 60 keys on the board. I am not a smart man  :blank:
The LED wiring + some of the matrix wiring.
Offline vorn
« Reply #37 on: Tue, 13 August 2013, 09:46:17 »
Really love this layout! Though I'm an ISO kinda guy. Maybe I'll get adventurous enough to follow your build process one day! Keep up the great work!
Offline MOZ
  • KING OF THE NEWBIES
  • Busy making stuff
« Reply #38 on: Tue, 13 August 2013, 17:01:43 »
This is beautiful, I love ghetto work!
Offline Dubsgalore
« Reply #39 on: Tue, 13 August 2013, 17:03:14 »
ghetto? this is far from ghetto son
Offline MOZ
  • Busy making stuff
« Reply #40 on: Tue, 13 August 2013, 17:26:38 »
Correction, DIY.
Offline lazerpointer
  • ya gotta stay phresh
« Reply #41 on: Tue, 13 August 2013, 17:54:59 »
That is one sexy Longcat! I like how the tenkey looks like the head, etc (in the OP pics.)
Glad to see there are people who will actually make a plan / design, follow through and execute successfully. Grats, TFR
i type, therefore i geekhack
  • HHKB Pro
« Reply #42 on: Mon, 02 September 2013, 14:23:30 »
Horizontal wiring finished. Now working on vertical wiring.
Offline AndyCapets
  • I have a French ANSI keyboard, kiss me now.
    • YouTube!
« Reply #43 on: Mon, 02 September 2013, 19:05:05 »
That looks... Actually there's no word to describe this, there is a heck of alot of work that went into that board and god it's awesome!
Not sure about the key placement though, but I guess you don't care since it's your project :D
I don't I like broccoli.
Offline AGmurdercore
« Reply #44 on: Tue, 03 September 2013, 01:43:06 »
This is awesome man, nice work!
What the hell am I even doing
Offline Hellmark
« Reply #45 on: Wed, 04 September 2013, 11:20:01 »
It is a really cool idea, and I've toyed with something similar on how you did the numpad (doing it with the keys from the top row), but I have to say, where is the enter key?
Offline wiredPANDA
« Reply #46 on: Wed, 04 September 2013, 11:51:20 »
Nice work on the board.
| HHKB Pro 2 | Leopold FC660C
| Poker.PANDAclears | ErgoDox (62g Black)
Offline pixel5
    • pixel5
« Reply #47 on: Wed, 04 September 2013, 12:05:28 »
What resistors/diodes did you use on the switches and LEDs? Thanks!
Poker II
Quickfire Rapid
BUY MY CRAP
  • HHKB Pro
« Reply #48 on: Wed, 04 September 2013, 22:22:40 »
The resisters for the LEDs are 150 ohmn and the diodes are 1N4148.
Offline pixel5
    • pixel5
« Reply #49 on: Thu, 05 September 2013, 08:39:34 »
Would you mind linking where you bought them from? I want to know where I can get the best price.
Poker II
Quickfire Rapid
BUY MY CRAP
