Author Topic: Dihedral 79 (80% Merged Ten Key board)  (Read 67953 times)
Offline Dihedral
  • Mostly Harmless
Re: Dihedral 79 (80% Merged Ten Key board)
« Reply #100 on: Sun, 24 May 2015, 00:38:53 »
One last thing then before declaring this complete - the keycap profile.  If it's not flat (really hope it isn't) does the bottom row of the D79 numberpad match the profile of the standard up arrow?  Would be a shame if it didn't :)
It's R1 so yes it should.
Offline Dihedral
  • Mostly Harmless
« Reply #101 on: Sat, 30 May 2015, 11:45:28 »
Offline Dihedral
  • Mostly Harmless
Re: Dihedral 79 (80% Merged Ten Key board) [PLATE IC ACTIVE]
« Reply #102 on: Fri, 19 August 2016, 17:50:14 »
 :blank:
This project IS still alive and I do want to make it work. More info coming, hopefully soon.
