Author Topic: I feel sorry for people that have to use these...  (Read 2249 times)
Offline roaduck
« on: Wed, 23 September 2009, 20:52:56 »
I couldn`t use this if my life depended on it!
Total bargain as well nearly £1000 without tax.
Lomak - The Light Operated Mouse and Keyboard
An innovative new way to operate a computer!
This light operated mouse and keyboard is a revolutionary concept in keyboard design that provides a new approach to the way a computer is operated.
Lomak uses state of the art light sensor technology to operate a computer.
A hand or head pointer controls a beam of light that enters, then confirms, any key or mouse function.
It is an affordable and effective alternative for anyone with a physical disability that prevents them from using a standard keyboard.
Operation is simple:
• Using either the hand or head pointer, highlight the key (or mouse function) you want.
• The key lights to show it has been selected.
• Enter the input by highlighting the confirm key.
Lomak is easy to use, with an intuitive layout and ergonomic design. Inputting is quick and natural, with little physical effort required.
• Requires no additional software - just plug and play.
• Compatible with Mac and PC.
• Lightweight and robust.
The Handpointer Set comprises a keyboard, handpointer and wrist rest.
The Headpointer Set comprises a keyboard, headpointer and laptop stand.
"the most exciting piece of kit I have seen in a long time..." Read the Guardian's review
http://education.guardian.co.uk/elearning/story/0,,1724606,00.html
http://www.inclusive.co.uk/catalogue/acatalog/Lomak.html
http://www.inclusive.co.uk/catalogue/acatalog/lomak_hand.jpg
BS : IBM 1391406
Other keyboards - don\'t ask
Offline hyperlinked
« Reply #1 on: Thu, 24 September 2009, 03:33:13 »
It looks like it sure beats using a mouth stick for people who have physical disabilities for the keyboarding part. The mousing part might be another story. I can't imagine trying to navigate an onscreen pointer through a keyboard that's activated by light.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline ch_123
« Reply #2 on: Thu, 24 September 2009, 04:34:18 »
If I had to use one of those, the awkwardness of using a computer would be the least of my concerns.
