Author Topic: RealForce 104ub high profile assembly.. What sliders go where?  (Read 1496 times)
Offline Dracarnion
So I pulled it apart to try some silencer rings, which I didn't like. Now I realize I should've noted which sliders go where as when I reassembled it, the keys were not at the correct high profile heights.
It seems they are labeled from 2-8 with some being blank. The dispersion is as follows:
2 - 13
3 - 13
4 - 14
5 - 15
6 - 8
7 - 12
8 - 11
Blank - 7
Any help is greatly appreciated
Offline Hyde
  • White Tofu Extraordinaire
Re: RealForce 104ub high profile assembly.. What sliders go where?
« Reply #1 on: Mon, 01 June 2015, 09:00:29 »
I always thought all the domes and slider are the same height but only keycaps have different profiles no?
Offline Dracarnion
« Reply #2 on: Mon, 01 June 2015, 09:42:40 »
Apparently not.  the caps are definitely a different height but I had all the sliders in 1 pile and put them back in and one I hooked everything up, the keys had different heights per row which looked wacky
