Author Topic: HKKB Type S Wireless  (Read 3801 times)
Offline beraken
« on: Mon, 01 June 2015, 13:24:53 »
Anyone owned this keyboard?
http://www.amazon.co.jp/Hacking-Keyboard-Professional2-%E7%99%BD%EF%BC%88%E8%8B%B1%E8%AA%9E%E9%85%8D%E5%88%97%EF%BC%89EneBRICK-KB400WS-EB01AH/dp/B00LUBYM9I/ref=sr_1_6?ie=UTF8&qid=1416380193&sr=8-6&keywords=hhkb+type-s
I am choosing bwtween this one and the wired type s version
And is the type s version really worth the price difference with professional?
Offline esoomenona
  • Gnillort?
« Reply #1 on: Mon, 01 June 2015, 14:16:25 »
« Last Edit: Wed, 12 August 2015, 09:15:39 by esoomenona »
Offline beraken
Re: HKKB Type S Wireless
« Reply #2 on: Mon, 01 June 2015, 14:29:43 »
It's just a Type S with a separate adaptor, which you can see in the pictures. You would still need to run a wire between the keyboard and the adaptor, and the adaptor seems to be fairly large in size. IMO, there are better options than this.
How about Type S and Professional?
Offline TopreFan333
« Reply #3 on: Mon, 01 June 2015, 14:30:44 »
I read through a bunch of reviews of this adapter thing on Amazon Japan. They were auto-translated, but you could get the jist -- a lot of people were complaining about it, saying it dropped the connection a lot, was badly designed, etc. It's a shame, because if this was *good* it would be a pretty cool mobile office setup in conjunction with an iPad or something.
Offline TopreFan333
« Reply #4 on: Mon, 01 June 2015, 14:32:34 »
There is no "wireless" HHKB stock model. All you're seeing there is a normal HHKB (US layout, Japanese layout, Type S, whatever) with this wireless adapter bundled.
As far as Type S versus the regular Pro model, the difference is that the former is designed to muffle the sound of the keyboard. There are a lot of videos on YouTube that will show you the difference in sound.
« Last Edit: Mon, 01 June 2015, 14:34:22 by dchadwick »
Offline yomammary
« Reply #5 on: Tue, 02 June 2015, 07:08:27 »
The wireless function is provided by the eneBrick, which doesn't have great reviews. I'd rather get Hasu's bluetooth controller (which I did) and it works great.
RF 87u 55g | Leeku 1800
Offline TopreFan333
« Reply #6 on: Tue, 02 June 2015, 09:18:30 »
How was installation? Did you have to solder?
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #7 on: Tue, 02 June 2015, 09:51:05 »
You do not need to solder at all. Just pop out the old one and install a battery.
https://geekhack.org/index.php?topic=71517.0
Offline yomammary
« Reply #8 on: Tue, 02 June 2015, 12:49:10 »
Exactly. You also need to configure it but it relatively easy to do.
Offline byker
  • Literally Canada
« Reply #9 on: Tue, 02 June 2015, 12:57:36 »
+1 for Hasu's bluetooth controller. I use one as well in my Type S and you cannot even tell it is installed as everything is inside the case. Much better than the Bluetooth adapters!
