Author Topic: Upgrade laptops keyboard?  (Read 1488 times)
Offline erebus
« on: Mon, 01 June 2015, 23:33:49 »
Hello everyone, i have an HP Probook 450 G1 laptop, it's pretty good for my needs but the keyboard is trash.
I'm used to old keyboards (like HP Compaq workstations) and mechanicals.
Is it possible to replace the keyboard with a better one? Even chiclet but a good one!
Re: Upgrade laptops keyboard?
« Reply #1 on: Tue, 02 June 2015, 00:14:06 »
Offline byker
  • Literally Canada
« Reply #2 on: Tue, 02 June 2015, 00:46:51 »
http://elitekeyboards.com/products.php?sub=pfu_keyboards,hhkbpro2 you're welcome
You can even get this + Hasu's bluetooth controller so that you have a wireless keyboard for your laptop. I use mine with my macbook and on the couch sometimes, works great!
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #3 on: Tue, 02 June 2015, 08:50:31 »
If you are talking specifically about the integrated keyboard, then no. The keyboards are way too thin to have any considerable travel distance and most are not cross compatible with other models.
