Author Topic: Wooden Retro Themed Keyboard (Anticipation of SA Retro Keycaps)  (Read 5154 times)
Offline yehoshuaf
http://imgur.com/a/u84eS
Nothing new about the design. I wanted a big ass wooden keyboard that looked kinda like an IBM space saver. It's not done yet. I'll save pictures for when the caps get here.
Offline azhdar
  • Praise the AZERTY god
Re: Wooden Retro Themed Keyboard (Anticipation of SA Retro Keycaps)
« Reply #1 on: Wed, 03 June 2015, 10:50:22 »
Looks great sir,
no doubt it will be great with SA Retro.
Azerty Propagandiste
« Reply #2 on: Wed, 03 June 2015, 10:52:31 »
Holy ****, I love seeing people making their own circuit boards or PCBs. Nice job :D
Offline greath
  • A waffle is like a pancake with a syrup trap.
« Reply #3 on: Wed, 03 June 2015, 10:59:54 »
The case is beautiful!
Offline nathanrosspowell
    • nathanrosspowell.com
« Reply #4 on: Wed, 03 June 2015, 11:22:04 »
Oh man, great work. Can't wait to see it set up.
Offline Oobly
« Reply #5 on: Wed, 03 June 2015, 12:08:29 »
That looks amazing! :) It'd suit the 1976 set VERY well also ;)
I bet it's going to feel lovely to type on. I've never tried a wooden plate / case before, but I want to and imagine it would have it's own, unique feel.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline flabbergast
« Reply #6 on: Wed, 03 June 2015, 12:22:08 »
Truly sublime!
« Reply #7 on: Wed, 03 June 2015, 15:13:48 »
Looks fantastic!
« Reply #8 on: Wed, 03 June 2015, 16:01:04 »
You can cut the internal plates of a regular Model M and fold the sheets underneath for a faux-SSK.
The only problem is the case.
If you could cut a nice wooden case for either standard M or SSK, there may be a market for quite a few of them. If you can cut square holes, you could probably re-use the yoke/frame for the SDL socket.
- D Trump 2026-10-24
Offline ghostjuggernaut
« Reply #9 on: Wed, 03 June 2015, 16:05:53 »
This looks amazing.  Great job.  I can't wait to see the finished project.
Offline rm-rf
« Reply #10 on: Wed, 03 June 2015, 16:20:55 »
that is some beautiful work.
i was planning on making something similar a while back.
might have to bring that idea back into my planner.
Offline BlueNalgene
« Reply #11 on: Wed, 03 June 2015, 16:31:40 »
Top notch.  I wish I had access to the equipment (and spare time) to do something similar.
Offline neverused
« Reply #12 on: Wed, 03 June 2015, 19:49:51 »
Very nice work!  Do you mind giving a quick explanation of how you made the layout for transferring to the copper board befire etching? . I would like to do something similar but have concerns about getting the component spacing right.
« Last Edit: Wed, 03 June 2015, 19:53:18 by neverused »
Offline yehoshuaf
« Reply #13 on: Wed, 03 June 2015, 21:35:37 »
Thanks for your comments. I'll post pictures when it's done and when I get the caps.
Offline yehoshuaf
« Reply #14 on: Wed, 03 June 2015, 21:47:52 »
Ya sure. I started by using the keyboard layout editor (http://www.keyboard-layout-editor.com/#/), which, admittedly, took about 15 seconds since I used the ANSI 104 key preset minus the number pad. Then, I used the amazing swillkb plate/case builder (http://builder.swillkb.com/ -- thanks @swill!). I only cared about the dfx vector files for my purposes. This gave me all the switch/stabilizer holes. In Vectric Aspire, I added the cutout/pocket paths I wanted. I made the holes for the CB manually in Aspire using the cherry switch docs. I copied and pasted these into the exact center of each switch hole. Amazingly it came out perfect the first time.
I've attached the vector files for the cherry switch PCB holes. Maybe you'll find them useful. I've also attached the vector files for the teensy holes, which I made and then subsequently cut off the CB, because I got frustrated trying to draw traces to them. :)
Offline yehoshuaf
« Reply #15 on: Wed, 03 June 2015, 21:49:11 »
It's all equipment. I'd say 4 hours of actual work so far.
Offline neverused
« Reply #16 on: Wed, 03 June 2015, 22:07:27 »
Awesome thank you!
Offline Yoe
  • Alps & ISO <3
« Reply #17 on: Thu, 04 June 2015, 01:23:19 »
Wow! Excellent wood work!! Looks absolutely gorgeous!
Offline vivalarevolución
« Reply #18 on: Thu, 04 June 2015, 08:21:00 »
That is a gorgeous case.
Offline rsbseb
  • -Horned Rabbit-
« Reply #19 on: Sun, 07 June 2015, 08:18:24 »
So very nice. You might try working some fiberglass resin into the back side of the switch plate area to stabilize it next time around . I look forward to seeing it with the retros
YMTRWV
Offline yehoshuaf
« Reply #20 on: Mon, 08 June 2015, 10:15:59 »
YMTRWV
Huh, interesting Idea. Just the resin? no fiber?
