Author Topic: Issue with Kinesis Advantage  (Read 1256 times)
Offline rebus
« on: Thu, 04 June 2015, 11:13:26 »
Hello, I have got a problem with my Kinesis Advantage: the "7" key does not output anything, or better, it does not output the digit 7. If I remap the digit 7 to another key, still that key does not output a thing. If I use the keypad, I manage to type the 7. But that's crazy!
Anyone else experienced this? Any suggestion? Thanks
Offline vvp
Re: Issue with Kinesis Advantage
« Reply #1 on: Fri, 05 June 2015, 13:56:48 »
Looks like faulty switch, or its diode, or trace on PCB which is specific for this switch. If there is such a trace (or better its branch) which goes only to this switch.
Offline Nai_Calus
  • CLACK
« Reply #2 on: Sat, 06 June 2015, 13:13:55 »
Could be a bad key or an issue with the traces leading to it. The design of the PCB for the hand cups means that 7 is going to be on its own at the end of a 'finger' of the PCB. Probably best to contact Kinesis. Trying to replace a switch on that board would be a nightmare and if it's the PCB that's even worse.
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
