Author Topic: Windows key activation on an old model M  (Read 10577 times)
Offline roaduck
« on: Thu, 24 September 2009, 22:08:50 »
You lot will probably know this hack but I`ll say it just in case.
Personally I hate Micro$$$$ and anything out of Redmond and I have never used the Windoze bloatware key in over ten years but somebody might want the keyboard shortcut to access it.All you do is press the left Ctrl and Esc simultaneously and viola.Works on my 1391406.
BS : IBM 1391406
Other keyboards - don\'t ask
Offline timw4mail
    • https://timshomepage.net
« Reply #1 on: Thu, 24 September 2009, 22:26:32 »
Yes and no. It works for the function of bringing up the Start menu, but it doesn't really work for shortcuts, or for command emulation on other Operating Systems.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline roaduck
« Reply #2 on: Thu, 24 September 2009, 22:45:17 »
True tim4mail but I don`t use OSX or dual-boot,I`ve got nested and cascaded ten plus folder deep access with a full command prompt just on my right-click menu.
BS : IBM 1391406
Offline roaduck
« Reply #3 on: Thu, 24 September 2009, 23:29:38 »
I`ve done a picture of the command prompt in the context menu.
BS : IBM 1391406
Offline pseudolobster
« Reply #4 on: Sat, 26 September 2009, 17:59:24 »
Yes, Ctrl+Esc brings up the start menu, and Shift+F10 brings up the context menu, but neither can be used as modifier keys. For instance, Winkey+D is the "show desktop" command, or Winkey+E is a shortcut to explorer, yet you can't press Ctrl+Esc+D or Ctrl+Esc+E to get those functions. For that you'll need to actually remap a key you don't use to the windows key.
Here:
Code: [Select]
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=hex:00,00,00,00,00,00,00,00,02,00,00,00,5b,e0,46,00,00,00,00,00
Paste that to a text file, save as .reg, and double click.. It'll remap scroll lock to the windows key.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #5 on: Sun, 27 September 2009, 00:35:11 »
The PS/2 to USB adaptor I use (PI Industries Y-Mouse) will let you map various bottom row keys to make a PC keyboard more adaptable for a Mac or give you some Windows key functionality on a 1391401.
Of course, it's like $60.
It's surprising that there aren't more "passthrough translators" you can program macros and such into, and keep your favourite keyboard behind them.
Overton130, Box Pale Blues.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #6 on: Sun, 27 September 2009, 10:59:14 »
Have you ever considered putting some keys in the cluster to the right of the QWERTY pad?
