Author Topic: [IC] XX7 Artisan Caps - DSA, OEM, MEGATRQN. Topre and MX (GB Started)  (Read 4715 times)
Offline 27
  • The Maple Man
Hello everyone!  I've been slowly getting together a groupbuy for some of my custom keycaps http://xx7keycaps.bigcartel.com
I have DSA, OEM, MEGATRQN keycaps available in both Topre and MX stems.  As of now I've selected the four patterns I'll be using.
103017-0
A couple of pictures to show texture and finish are here http://imgur.com/a/3epuC
I'd love to hear any suggestions you have!  :thumb:
Groupbuy Open: https://geekhack.org/index.php?topic=72901.msg1779901#msg1779901
« Last Edit: Fri, 19 June 2015, 22:59:40 by XX7 »
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
Offline pkircher
Re: [IC] XX7 Artisan Caps - DSA, OEM, MEGATRQN. Topre and MX
« Reply #1 on: Mon, 08 June 2015, 07:24:25 »
not sure if a extrudet cap is something people are actualy willing to pay for ..
it lacks detail, unless you spend alot time in manualy sanding them .. (not easy if the cap isnt flat)
did you consider SLA and paint or resin cast ?
« Last Edit: Mon, 08 June 2015, 07:29:56 by pkircher »
Offline 27
  • The Maple Man
« Reply #2 on: Mon, 08 June 2015, 07:31:00 »
did you consider SLA and paint ?
These aren't extruded. They're printed on a powder bed printer, so they're very smooth even without finishing.  Printed on the ProJet4500 in full-colour nylon.
Offline pkircher
« Reply #3 on: Mon, 08 June 2015, 07:34:39 »
what pricepoint are we looking at aprox?
Offline 27
  • The Maple Man
« Reply #4 on: Mon, 08 June 2015, 07:36:59 »
$12@20, $10@50, $7@100
Offline 27
  • The Maple Man
Re: [IC] XX7 Artisan Caps - DSA, OEM, MEGATRQN. Topre and MX (GB Started)
« Reply #5 on: Tue, 16 June 2015, 21:27:20 »
Alright guys I opened up the order form so go nuts.
Offline heedpantsnow
  • Old enough to know better
« Reply #6 on: Tue, 16 June 2015, 21:33:48 »
Agh, I ordered anyway even though no Hyperfuse. If you changed your mind and wanted to do one of mine on Hyperfuse I wouldn't object
I'm back.
Offline 27
  • The Maple Man
« Reply #7 on: Thu, 18 June 2015, 15:34:15 »
Eh may as well.
