Author Topic: If you own a FC660M with the grey dye sub caps please come in!  (Read 2592 times)
Offline Sencha
  • HHKB Pro
  • MX Reds <3
Just about to get another FC660m but this one is Korean made and has the standard space bar stems. I know the grey dye subs fit the chinese made with the narrow stems but does the space bar cap have stems for standard as well?
Many thanks
Offline Blackehart
Re: If you own a FC660M with the grey dye sub caps please come in!
« Reply #1 on: Mon, 08 June 2015, 10:55:42 »
Where are you purchasing it from?  :o :o :o
Offline Sencha
  • HHKB Pro
  • MX Reds <3
« Reply #2 on: Mon, 08 June 2015, 14:53:31 »
widebasket on eBay. Amazing seller. best service I've had
Offline Blackehart
« Reply #3 on: Mon, 08 June 2015, 15:05:35 »
Pardon my hijacking of the thread but, how do you know it has a standard space bar?
I looked at his ebay store and didn't see anything different from other fc660ms.
Offline Latin00032
« Reply #4 on: Mon, 08 June 2015, 16:22:26 »
Sencha,
There was multiple discussions that I had in other threads about this topic.
We are trying to figure out which fc660m's work with gateron pbt keycaps.
Do you have any info I this?
Offline Sencha
  • HHKB Pro
  • MX Reds <3
« Reply #5 on: Mon, 08 June 2015, 17:05:32 »
All I can say is that I have used a Korean fc660m before which I bought from widebasket, and it has the standard space bar stems. The China made one has the crazy narrow which I've seen in person.
Offline Sencha
  • HHKB Pro
  • MX Reds <3
« Reply #6 on: Mon, 08 June 2015, 17:06:53 »
Can any one with the grey dye subs let me know if it has both positions on the space bar. Thanks guys
Offline Latin00032
« Reply #7 on: Mon, 08 June 2015, 19:19:48 »
I think I'll go with this answer. I wanted to buy one from him in hopes that the spacebar would work.
Offline Sencha
  • HHKB Pro
  • MX Reds <3
« Reply #8 on: Tue, 09 June 2015, 04:40:57 »
Yeah they are very nice. Just means all you have to deal with is the right 2.25 shift but that's easy. The boards are superb as well. So much better build then the pokers. Rock solid.
