Author Topic: What's the difference between the 2923, 3923, 5923, 6923, 7923, 8923 keyboards?  (Read 3196 times)
Offline EscapeVelocity
  • Antiquarian
Vintage rubber dome keyboards.
Is the higher the number the better quality, or are these likely using the same parts?
Those sound like Chicony numbers in which case nothing makes sense.
Numbers usually just relate to series and layout/design.
  • Antiquarian
So it's not like A/V equipment where the higher up in the range of performance & build quality?
Offline dante
Buy a Topre keyboard.  Much nicer rubber domes than vintage.
  • Antiquarian
Got it on my list here.
