Author Topic: Youtube Embed Functionality  (Read 18130 times)
Offline user 18
« on: Mon, 08 June 2015, 21:03:30 »
After a long wait, youtube embeds work again, in http and https flavours! https is recommended, as it will show up for most users by default. Just put the URL of the video in your post, and it should automatically embed. If you encounter any problems, please post below and let us know.
E: If you want to just link a video, rather than embed, you can wrap it in a url tag:
https://www.youtube.com/watch?v=dQw4w9WgXcQ
« Last Edit: Mon, 08 June 2015, 21:16:54 by user 18 »
Avatar by ashdenej
Re: Youtube Embed Functionality
« Reply #1 on: Mon, 08 June 2015, 21:05:55 »
Well, it embeds just fine....but it doesn't play, at least not in chrome.
Offline exitfire401
  • The Force is Re/\l
« Reply #2 on: Mon, 08 June 2015, 21:09:30 »
Working fine in my chrome.
Offline user 18
« Reply #3 on: Mon, 08 June 2015, 21:10:24 »
Works for me on chrome under both Windows and Linux. If you can get me your OS and browser version, I'll see that it's looked into.
Avatar by ashdenej
« Reply #4 on: Mon, 08 June 2015, 21:10:58 »
Version 43.0.2357.81 m
Win7 x64
Tried it with all extensions disabled too, no dice.
« Last Edit: Mon, 08 June 2015, 21:13:00 by nubbinator »
« Reply #5 on: Mon, 08 June 2015, 21:12:59 »
Yes, I noticed that... when I had intended to post a regular link to a Youtube video...  :rolleyes:
Offline user 18
« Reply #6 on: Mon, 08 June 2015, 21:13:51 »
Yes, I noticed that... when I intended to put a regular link to a Youtube video...  :rolleyes:
Wrap it in a [url] tag if you just want to link
Avatar by ashdenej
Offline tbc
« Reply #7 on: Tue, 09 June 2015, 00:13:32 »
working fine on windows 8.1
Offline user 18
« Reply #8 on: Thu, 11 June 2015, 22:31:33 »
Win7 x64
I could not reproduce the issue using the same browser version and OS.
Have you tried clearing cache, cookies, etc.?
Avatar by ashdenej
« Reply #9 on: Thu, 11 June 2015, 22:32:34 »
'bout time!  Thanks for this
Offline baldgye
  • Will Smith Disciple
« Reply #10 on: Mon, 15 June 2015, 03:55:32 »
umm... I can't get any youtube video's to play, clicking them does nothing for me at work or home on chrome or FF... what am I doing wrong?
« Reply #11 on: Mon, 15 June 2015, 08:21:08 »
Heh, me too.  I should have tried it before I posted.
« Reply #12 on: Mon, 15 June 2015, 15:14:10 »
Works for me - the video in the OP of this thread shows a preview, then I click it it starts playing.
« Reply #13 on: Mon, 15 June 2015, 17:10:24 »
Not working in IE 11 at work either.  Version: 11.0.9600.17801
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #14 on: Wed, 17 June 2015, 01:21:27 »
Can I get enough details on failures to repro? I can't debug this without repro
Offline baldgye
« Reply #15 on: Wed, 17 June 2015, 03:52:47 »
repro?
work machine win7 using chrome v43.0
home machine win7 using ff v(latest I cant remember the exact version)
« Reply #16 on: Fri, 19 June 2015, 18:22:14 »
Apparently there is a single flaw with the Supreme Theme, Austere.  Youtube embeds do not work.  :-/
Everyone having issues, could you post which theme you're using, and whether switching from Austere to another one fixes it?
I, for one, will stand firm and go without Youtube videos for the sake of my eyes.  :'(
Offline Coreda
« Reply #17 on: Fri, 19 June 2015, 19:05:43 »
Yay, thanks user 18!
Now all I need to enable is the jquery.org JS and voila. The previous implementation never worked for me.
Offline tbc
« Reply #18 on: Fri, 19 June 2015, 22:34:55 »
what solution are you talking about?
Offline user 18
« Reply #19 on: Fri, 19 June 2015, 22:51:33 »
This actually brings the flaw count with Austere up to two -- the first being that it's not Nostalgia :P
Avatar by ashdenej
Offline Coreda
« Reply #20 on: Fri, 19 June 2015, 23:01:31 »
I meant that all I have to do now is enable jquery.com (and Geekhack's) Javascript with NoScript on Firefox and the embedded video displays. In the previous version enabling all scripting still didn't get it to display.
Probably was some config setting on my end, but happy it's all gravy now.
« Reply #21 on: Sat, 20 June 2015, 03:37:07 »
FWIW works for me, using Nostalgia :D
Offline baldgye
« Reply #22 on: Sat, 20 June 2015, 05:18:18 »
Yeah I'm using austere. I don't know how people can read white text on a black background for long periods of time... Ruins my eyes
Offline mkawa
« Reply #23 on: Sat, 20 June 2015, 07:49:22 »
oh, yah, we're pulling down our jquery from off-site, so if you have noscript or some other aggressive same origin filter, the youtube scripts won't run until you whitelist them
austere derives from the same template as nostalgia, so if austere has issues with your browser and plugin setup,  nostalgia should have the same problem..
can the people having trouble try to reproduce the problem with windows 8 or macos and a current browser version with no plugins and cookies wiped? i want instructions to reproduce the problem on my end with the most straightforward possible configuration -- that will point to the error (more likely some dodgy trick that is fine in some versions of chrome but not in firefox or IE..)
« Reply #24 on: Sat, 20 June 2015, 08:58:50 »
I'm using the Austere theme.  It doesn't work.  Using Firefox.
All I have to do to fix it is log out.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #25 on: Sat, 20 June 2015, 11:20:27 »
I use austere and chrome and it works if that is any help?
Offline tbc
« Reply #26 on: Sat, 20 June 2015, 18:44:01 »
read?  on gh?  i'm here for the hoff nudes.
bu seriously, gh isn't the only site i read and everyone else does BOW aka i don't spenf long periods of time reading here.
Offline mkawa
« Reply #27 on: Sat, 20 June 2015, 21:20:08 »
yah, nothing wrong with austere except a few cobwebs and this bug.
Offline mkawa
« Reply #28 on: Sat, 20 June 2015, 21:40:06 »
fixed
« Reply #29 on: Sat, 20 June 2015, 22:17:47 »
confirming fix
finally everything is only 1 button away instead of two
