Author Topic: Do you know anything about Exact Audio Copy ?  (Read 2818 times)
Online fohat.digs
« on: Tue, 09 June 2015, 10:05:25 »
I have a recent install of Exact Audio Copy and I cannot get it to rip CDs to .MP3 at higher than 192 bits.
I have gone into settings and set them to 320 bit, and it seems to register (still set at 320 afterwards) but the final rips themselves do not exceed 192 (usually they vary from song to song in the 180-192 range).
*Also, off-topic but related, I have used Imgburn in the past for burning, but when it opens now, all the options are grayed out.
As I remember, there is no direct audio CD burning, but in the past I was able to make an .ISO image and burn that, but not now.
My immediate project is that I just got a remastered audiophile CD and I want to burn a copy to use in my car, but I want to solve this for future work.
- D Trump 2026-10-24
Re: Do you know anything about Exact Audio Copy ?
« Reply #1 on: Tue, 09 June 2015, 10:10:59 »
For burning audio I use CDBurnerXP, can't comment on EAC haven't used it in a long time.
In this case can you just make an iso image of the disc and burn that image versus ripping tracks? Or maybe I'm missing something.
Offline greath
  • A waffle is like a pancake with a syrup trap.
« Reply #2 on: Tue, 09 June 2015, 10:11:40 »
Are you a what.cd member? They have a step by step guide. If not I can grab some screenshots of the guide and upload it.
« Reply #3 on: Tue, 09 June 2015, 10:24:56 »
There used to be a REALLY good one on some blowfish website, but it seems the domain is no longer active and sadly I didn't save the tutorial. That's how I got my setup going a couple of years ago and it's worked perfectly since.
Doing a quick DuckDuckGo search brings me the following article, and it seems to be pretty good (even references the comprehensive blowfish tutorial):
http://filesharingtalk.com/threads/435208-Installing-configuring-and-ripping-with-Exact-Audio-Copy-(EAC)
