Author Topic: Portable Oscilloscope  (Read 2918 times)
Offline Blaise170
  • ALPS キーボード
    • XYZ
« on: Tue, 09 June 2015, 23:13:35 »
Hi guys, I am thinking about picking up an oscilloscope for hobby work for when I'm working on electrical projects from audio to keyboards to computers. I don't have a substantial budget, but I want to make sure I get a quality oscilloscope. Does anyone have any suggestions for one that is less than around $80?  :)
Offline neverused
Re: Portable Oscilloscope
« Reply #1 on: Tue, 09 June 2015, 23:18:23 »
For a keyboard, what do you need the oscilloscope for? Wouldn't a good dmm be more useful?
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2 on: Tue, 09 June 2015, 23:29:23 »
Anything capactive, model F and topre, especially when working on custom pcbs for each, would require one.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #3 on: Tue, 09 June 2015, 23:31:52 »
Even if I didn't need it for keyboards, I still need it for other things too, notably some audio equipment I'm working on.  :thumb:
Offline neverused
« Reply #4 on: Tue, 09 June 2015, 23:42:54 »
That's true, the lowest price I remember seeing for a "pocket nano" oscilloscope was ~$90. Though I'm not too sure how much choice you'll have to pick through.
Offline dndlmx
« Reply #5 on: Wed, 10 June 2015, 00:59:39 »
Maybe look at this it's for ee students.
Offline phoenix1234
« Reply #6 on: Wed, 10 June 2015, 01:12:43 »
It depends on your needs. The portable oscilloscope is usually expensive actually, so if you need something high quality, it would be conflict with your budget 80$. However, if you only something with low MHz, you can consider VELLEMAN HPS140i:
http://www.amazon.com/VELLEMAN-HPS140I-HANDHELD-POCKET-included/dp/B004KKTUV6#customerReviews
I like linear switches
