Author Topic: DSA Minimalistic Dolch 'Granite' set  (Read 2724 times)
Offline nielstrumpie
« on: Wed, 10 June 2015, 03:37:50 »
Hey guys,
Does anyone know if the base set seen on this board - or something similar - will be available again at
some point? I really like these particular legends (note the single characters on the number row and ,.?:"[] etc).
This seems to be the only image around. I would love to get them in the typical Dolch dark grey, for my Pok3r.
http://keypuller.com/granite/
Thanks a lot!  :)
Offline MAR82
  • Keyboard Addict
Re: DSA Minimalistic Dolch 'Granite' set
« Reply #1 on: Wed, 10 June 2015, 03:55:29 »
In that picture they are using the Ganite set from Matt3o with the extra Mono Legends kit
http://www.pimpmykeyboard.com/deals/granite-mono-legend/
Matt3o ran the set once with pimpmykeyboard.com and has now run twice on Massdrop.com, so with a bit of luck there will be a 4th run of that set and you'll be able to get them. Otherwise you'll just need to keep an eye out for a used set
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #2 on: Wed, 10 June 2015, 04:00:31 »
Hey guys,
Thanks a lot!  :)
There was a recent round done on Massdrop. There are a lot of people with this set, and you could probably browse the classifieds to find someone willing to sell. You won't be able to post an advert to buy in there yourself for a while though.
There are a lot of images at the bottom of that page, and it also states that there were options to create them in beige and Dolch charcoal, but they were never followed through with.
Offline lasttycoon
  • Ergonomic Wizard
« Reply #3 on: Wed, 10 June 2015, 14:10:30 »
This is a very popular set and with any luck the new PimpMyKeyboard.com store will reprint them with their new store set up.
Kinesis Advantage | Ergodox EZ Browns | RK RC930 | DS 3 Blues
« Reply #4 on: Thu, 11 June 2015, 09:56:47 »
There are thousands of those sets out there. I'm sure you could dind obe for sale in the classifieds or on mechmarket
