Author Topic: Geekhack's prefered hybrid layout  (Read 1989 times)
Offline blcksqrrl
  • I'm afraid that I just blue myself
« on: Thu, 11 June 2015, 23:21:01 »
I am interested to here if you guys like hybrid boards, and if so, what switches you prefer where?
Poker II MX Blue
KUL ES-87 MX Blue
Apple Standard Keyboard
Apple Extended Keyboard II
Offline davkol
  •  Post Editing Timeout
Re: Geekhack's prefered hybrid layout
« Reply #1 on: Fri, 12 June 2015, 15:52:38 »
Hybrid what?
Offline Sn0_Man
« Reply #2 on: Fri, 12 June 2015, 15:54:51 »
I assume he means different stiffness switches in different locations, like some topre boards have 45g alphas and 30/35g mods iirc?
Pok3r w/Clears & blank PBT
Offline Sn0_Man
« Reply #4 on: Fri, 12 June 2015, 16:02:11 »
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1153
That looks like its more designed to use every possible switch type than to optimize useability... pretty funny though.
Offline blcksqrrl
« Reply #5 on: Fri, 12 June 2015, 16:06:41 »
Yeah, I've seen a couple DIY boards with one switch type for the alpha and another for the mods. For the life of me, I can't find some of the posts that I've seen them in. I'll keep looking and report back.
Poker II MX Blue
KUL ES-87 MX Blue
Offline davkol
« Reply #6 on: Fri, 12 June 2015, 16:08:16 »
Variable weight? I see. I've been confused, because I've noticed the word "hybrid" in all sorts of context from touch/gestures to, eh, NovaTouch MX-compatible stems.
I hate variable weight, because I don't type 100% time. Having some keys stiffer than others in, say, a WASD-like cluster is just wrong.
Offline wlhlm
« Reply #7 on: Fri, 12 June 2015, 16:08:44 »
I've had a similar question. Maybe that helps: https://geekhack.org/index.php?topic=70934.0
Offline blcksqrrl
« Reply #8 on: Fri, 12 June 2015, 18:56:17 »
That had a lot of good information, thanks.
Poker II MX Blue
KUL ES-87 MX Blue
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Sat, 13 June 2015, 09:01:43 »
I put lighter switches on modifiers quite a bit when I build things... like blacks with red mods, clears with brown mods, white with blue mods. Always put stiffer switch than alphas on spacebar. Generally I don't care to mix linear/tactile/click together though.
