Author Topic: Model M – fixing a cracked barrel  (Read 1197 times)
Offline ander
  • I type, therefore I am
« on: Fri, 12 June 2015, 05:02:25 »
Hi guys,
I found that a piece had broken off from one of the barrels on the Model M I'm restoring. Here's an easy and effective way to repair it. You'll need:
  • A super glue "all plastics" kit, consisting of a marker-like Activator pen and some glue. (Two brands I know of are Loctite and LePage's.)
  • A small bottle of super glue with a brush applicator. (Dollar stores usually have them.)
  • Open the Activator and apply it to the broken surfaces of both the barrel and the broken-off piece. Be sure to completely cover both breaks.
  • Wait one minute for the Activator to take effect.
  • Brush some super glue onto barrel's break.
  • Fit the broken-off piece back into the barrel and hold it for a few seconds.
  • Wait several minutes before replacing the key stem and cap.
