Author Topic: What keyboard testing utility do you recommend?  (Read 7169 times)
Offline EscapeVelocity
  • Antiquarian
« on: Sat, 13 June 2015, 21:01:10 »
Thanks. Gonna test some of my vintage keyboards.
Offline E TwentyNine
    • Some of My Keyboards
  • Antiquarian
Re: What keyboard testing utility do you recommend?
« Reply #2 on: Sat, 13 June 2015, 21:51:54 »
Thanks mate!  Just what I needed!
Offline False_Dmitry_II
« Reply #3 on: Sun, 14 June 2015, 00:01:53 »
Definitely. I still haven't seen one that even compares.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #4 on: Sun, 14 June 2015, 00:23:06 »
I use elite keyboards program called Switch hitter.  The nice thing about this program, is it can alert you to bouncing keys.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #5 on: Sun, 14 June 2015, 00:31:01 »
It's not exactly a "test" program, but I use WhatPulse.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
  • Antiquarian
« Reply #7 on: Sun, 14 June 2015, 00:45:37 »
Thanks for all the recommendations so far...
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #8 on: Sun, 14 June 2015, 05:55:47 »
I use Switch Hitter, but I'll check out this Aqua thing too.
Offline phoenix1234
« Reply #9 on: Sun, 14 June 2015, 07:54:58 »
I used both AquaKeyTest and Switch Hitter.
AquaKeyTest can be standalone application and Switch Hitter required a installation.
Both of them are general good and light weight.
If I must choose only one, I will choose Switch Hitter because it can detect the key chattering problem which is likely happening with mechanical keyboard.
I like linear switches
Offline chyros
  • a.k.a. Thomas
« Reply #10 on: Sun, 14 June 2015, 08:48:55 »
Just tried Aqua; it's not too special tbh. I'd say Switch Hitter is better; allows for different layouts, higher contrast and colour customisation and chatter detection, none of which Aqua has.
Offline davkol
  •  Post Editing Timeout
« Reply #11 on: Sun, 14 June 2015, 12:07:29 »
Microsoft's web applet… it works only for some keys, but runs in any modern mainstream browser.
Otherwise, I use showkey.
