Author Topic: Woot Electronics Mechanical Keyboard Sale  (Read 2217 times)
Offline getf
  • In Rod We Trust
« on: Sun, 14 June 2015, 16:27:14 »
http://computers.woot.com/plus/hawt-keyboards?ref=cnt_wp_15
3 DAS TKL Boards for 89.99 each (Blue and brown switches)
3 Razers
Like most of electronics Woot sells, these are factory refurbished.
« Last Edit: Sun, 14 June 2015, 16:32:47 by getf »
Offline jerue
  • (Whenever that happens :P)
Re: Woot Electronics Mechanical Keyboard Sale
« Reply #1 on: Sun, 14 June 2015, 20:48:51 »
I can't really speak for the Das boards, but the 4C seems to not be as well received as the regular 4  :( . These use Gaterons IIRC. I think I got to use a 4C once, definitely don't like it as much as the regular 4 Professional.
The Razer BlackWidow Mac should have MX Blues. The 2014 edition BWU of course will have Kailh greens; the regular BWU is already sold out.
Offline missalaire
  • Great Finder of Great Finds
« Reply #2 on: Sun, 14 June 2015, 21:32:26 »
Prices aren't really that great.
Offline FoxWolf1
  • 154
« Reply #3 on: Sun, 14 June 2015, 22:27:36 »
Greetech, not Gateron. Greetechs are cheaper.
How cheap are they? Well, here's a reference point. You could get the reconditioned Das 4c with Greetech switches for $90, or, via Massdrop, you could spend $70 to get a brand new RK RG987, also with Greetech switches, but also with doubleshot keycaps and RGB backlighting. Both are made in China, and neither has a great reputation for quality (but, for the price of a new Das 4c and a few dollars more, you could buy two RG987s and just swap in the second one when the first one breaks).
Offline berserkfan
« Reply #4 on: Mon, 15 June 2015, 12:57:12 »
try jd.com if you don't want to wait
