Author Topic: removable usb mod for realforce?  (Read 2835 times)
Offline last100yen2
« on: Tue, 16 June 2015, 15:48:43 »
I am thinking about modding my realforce so that its USB can be removable.
I want to do this because I have HHKB professional and I use this keyboard daily, but sometimes I like to use my realforce(For gaming)
I found on thread about this, but it did not give me all the information I needs(I am noob at modding keyboard0
Can someone direct me in right direction? Is this hard mod to do?
Re: removable usb mod for realforce?
« Reply #1 on: Tue, 16 June 2015, 16:29:44 »
A USB cable is just four wires so in simple terms to make it removable all you need to open the case, cut the cable slightly longer than you need (just in case) and solder on a socket with the wires in the right order.  There are many harder things to solder, but a little experience would be helpful.  Either put the socket in a helping hand while you solder it or if you don't have one put it on the end of a cable so you have something to grip.
The hardest part is enlarging the hole in the case to fit the socket into without it looking bad, and keeping the socket in place in said hole as it is repeatedly pushed inwards whenever you plug in a cable.
Hard is relative, I'm assuming there is a bit of space in the case as if there isn't this might be much harder - open it up and have a look :)
Offline Xowie
  • On Sabbatical
« Reply #2 on: Tue, 16 June 2015, 19:23:05 »
If you want a different case and are looking to spend a lot of money, you could check out the digilog cases.
RETIRED
Offline last100yen2
« Reply #3 on: Tue, 16 June 2015, 21:44:19 »
I am looking for metal case, but no luck......do you know anyone who are trying to sell it?
Offline last100yen2
« Reply #4 on: Wed, 17 June 2015, 07:49:52 »
Where can I purchase the 4 pin connector that fits realforce?
Offline azhdar
  • Praise the AZERTY god
« Reply #5 on: Wed, 17 June 2015, 08:55:45 »
Get in touch with pexon :
http://pexonpcs.co.uk/products/realforce-cables
He might be able to do them like he does on the filco :
http://pexonpcs.co.uk/products/filco-keyboard-mods
Azerty Propagandiste
« Reply #6 on: Wed, 17 June 2015, 19:20:05 »
Any "where can I buy ..." question gets better answers when you say where you live, and any connector question gets better answers with a pic of the connector you want - it may well be used in many other makes/models :)
