Author Topic: b.mini x2 (75%)  (Read 2654 times)
Offline digi
  • elite af tbh
  • keyboard game on fleek
b.mini x2 (75%)
« on: Fri, 19 June 2015, 13:09:08 »
Any of you try this pcb? Which case did you get? Looks like that diffuser case is the way to go....nothing to see here, just thinking out loud, talking to myself. :))
http://winkeyless.kr/product/b-mini-x2-pcb/
« Last Edit: Fri, 19 June 2015, 15:30:21 by digi »
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: b.mini x2 (75%)
« Reply #1 on: Sat, 20 June 2015, 08:46:38 »
I have the b.face, and I can tell you the difference between any of the original vs x2. The original ones had PCB masking areas for RGB LEDs to be directly soldered on, and a small breakout PIN set for using wires to solder on a strip of RGB LEDs. In X2, he got rid of the breakout pin set and now has both sets of RGB LEDs soldered directly onto the board. I have the RGB diffuser case and my top case parts are frosted matte acrylic to match the diffuser case and I like it a lot.
