Author Topic: A few questions regarding lubrication and stem swapping  (Read 1471 times)
Offline Mooksie
« on: Fri, 19 June 2015, 23:51:13 »
Hey guys, hopefully you can help me out. I have 2 questions.
2. What's the best lube for linears? A thicker grease, a thin lube, or a mixture?
1. If I use a gateron linear stem in an mx switch, is it smoother than mx or close to gateron at all? What about a vintage black stem in a newer, but broken in, housing? If someone could please try this I would be eternally grateful!
Thanks!  :thumb:
we use up all the cupholders during our furious love making sessions
Re: A few questions regarding lubrication and stem swapping
« Reply #1 on: Fri, 19 June 2015, 23:54:34 »
2) I like a medium viscosity but I think a thinner lube would be fine.
1) I did that experiement in this review.
Offline Mooksie
« Reply #2 on: Fri, 19 June 2015, 23:59:59 »
Thank you for the info. Sorry if I seem daft but I read through the whole thing and didn't see a mention of how a gateron black stem felt in a cherry housing.
« Reply #3 on: Sat, 20 June 2015, 00:01:53 »
It was all right. Slightly smoother than a vintage Black but not as good as a stock Gateron IMO. Really no point in swapping the housings and stems. Just use vintage Blacks or Gateron Blacks and lube. I prefer lubed Gateron Blacks.
Edit: Should'ved linked this instead
https://geekhack.org/index.php?topic=69644.0
« Last Edit: Sat, 20 June 2015, 00:03:39 by CPTBadAss »
Offline Mooksie
« Reply #4 on: Sat, 20 June 2015, 00:04:39 »
Thanks. I just really don't want to desolder the switch bottoms from my poker x.
