Author Topic: best acrylic for plate making  (Read 3610 times)
Offline lucaslink
« on: Sat, 20 June 2015, 10:41:05 »
wondering if someone could point me in the right direction for what the best acrylic/lexan might be for making custom plates. I have access to a laser cutter and want to pick up some acrylic to do some experiments next week. the plates in my existing boards are all stainless steel, and while i realize there is no sheet that will give the same rigidity i would love to get some feedback if anyone has had success with this in the past. recommendations?
THANKS!
Offline lucaslink
Re: best acrylic for plate making
« Reply #1 on: Sat, 20 June 2015, 11:25:18 »
acrylic might not be the best word. material other than metal that i can use in a laser cutter.
im thinking nylons, polycarbonates, lexans, plexi, etc.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #2 on: Sat, 20 June 2015, 14:20:16 »
1.5mm is the most common thickness, not sure about other types of acrylic though... I know just general acrylic, carbon fiber, and polycarbonate are probably the most common alternatives to metal plates
Offline lucaslink
« Reply #3 on: Sat, 20 June 2015, 14:52:59 »
word. i picked up a sheet of 3mm acrylic at a local hardware store and i have some nylon i could experiment with.
i think nylon would be the best metal alternative but i believe only nylon 6/6 can be laser. i have to special order it and its kind of expensive. we'll see how this 3mm clear acrylic goes.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #4 on: Sat, 20 June 2015, 14:54:01 »
I know with carbon fiber they have to use a water jet to cut it
Online Findecanor
« Reply #5 on: Sat, 20 June 2015, 17:40:47 »
Wood can be laser-cut. Use of 3.6mm plywood is quite common. MDF too. The downside is that the edges will be burnt.
Offline heedpantsnow
  • Old enough to know better
« Reply #6 on: Sat, 20 June 2015, 23:24:05 »
I'm having one made of delrin right now.
I'm back.
« Reply #7 on: Sun, 21 June 2015, 00:48:06 »
Unless you are getting the plates machined you absolutely need 1.5mm. Otherwise the switches will not latch onto the plate. If you want thicker than 1.5mm you need to mill out notches to make the area where the switch would normally latch on 1.5mm, so that they can latch on.
Offline lucaslink
« Reply #8 on: Sun, 21 June 2015, 11:22:17 »
can you tell this is my first go at this? ;) thank you kindly for the information. any idea how or why Moz's acrylic case build used 3mm for the plate (https://geekhack.org/index.php?topic=48007.msg1030913#msg1030913 ?) i definitely won't be able to mill out notches as this will be laser cut only. i'm still trying to find a decent priced cnc machinist but wanted to get started with laser engraving keycaps and cutting plates/cases for fun.
« Reply #9 on: Sun, 21 June 2015, 13:57:05 »
1.5mm acrylic cracks really easily. So some use 3mm and just hot-glue the switches in instead of relying on the clips.
I'm back.
« Reply #10 on: Sun, 21 June 2015, 14:20:46 »
Or use polycarbonate instead ;)
Offline neverused
« Reply #11 on: Sun, 21 June 2015, 14:28:36 »
PETG is another alternative, ideally you should research different material characteristics and decide from there.
Offline nephiel
« Reply #12 on: Sun, 21 June 2015, 14:39:19 »
How about FR4? That fiberglass PCBs are made of?
Most PCB fabhouses can do cutouts. I just checked out OSHPark, board thickness is 1.6mm and they charge a flat rate by the square inch.
You could even add traces for extra LED lighting or whatever.
Stop wasting space! Chop your spacebar into bits!
NPH60: a custom 60% w/TrackPoint & split spacebar
Offline lucaslink
« Reply #13 on: Sun, 21 June 2015, 20:46:22 »
any idea where to find polycarbonate sheets in metric gauges? imperial is available but looks like 1/16 is about the closest which is 1.6mm~. maybe work?
since i have the 3mm im going to cut it and see what happens. there seem to be quite a few phantom builds with 3mm plates and a lot of talk about how brittle the 1.5mm stuff is and how easily it cracks. seems like.. i should maybe run ANOTHER cnc phantom plate gb.
thats... a pretty rad idea.
« Last Edit: Sun, 21 June 2015, 20:47:58 by lucaslink »
