Author Topic: DAC or New Cans?  (Read 5527 times)
Offline chuckster
DAC or New Cans?
« on: Sun, 21 June 2015, 14:59:32 »
Hi all, I listen to music primarily through my PC or on the go with my Galaxy S5. I have AT ATH-M50's that are a few years old but going strong. I really want to step up and see how much better my music can sound (it's all FLAC direct from CD, so no worries there), and I was wondering whether I should just get a DAC (I'd like a portable one, but if the desktops blow them away, I can give up some quality while traveling), or invest in a higher-end set of headphones like the AKG 701's or some Sennheisers, (or anything else you guys recommend.
I will eventually upgrade the cans anyway, but that represents a much bigger chuck of change than a DAC. I'd like to stay within a $250 budget for the DAC or a $500 for the new headphones.
So TL;DR, will I get higher quality sound plugging some higher-end headphones that the M50's, or from pairing them with a DAC? I go through an old soundcard right now, but I don't think it acts as a DAC.
Offline Sniping
Re: DAC or New Cans?
« Reply #1 on: Sun, 21 June 2015, 15:20:22 »
New headphones for sure.
Offline chuckster
« Reply #2 on: Sun, 21 June 2015, 16:41:56 »
Thanks Sniping, did you try a DAC and not get a major improvement, or are you just a fan of another pair of headphones? I'd love any recommendations for an upgrade.
Offline Oobly
« Reply #3 on: Sun, 21 June 2015, 16:55:09 »
Hard to say, depends how decent your current soundcard is, I guess. All soundcards do the function of a DAC, converting a digital signal to analogue (DAC=Digital to Analogue Converter), but they vary greatly in quality of chip used, grounding and shielding, noise, etc.
One problem you may have with a top notch set of 'phones is your sound card may struggle to drive them if they're higher impedence. A good protable DAC can make a huge difference in terms of separation and clarity, but the ATH-M50's can still be a touch muddy and bass-oriented.
I'd recommend aiming to get both, and maybe start with the DAC, but I'd probably stay away from the K701's. They will sound a lot more "open" than your M50's, but they lack richness in the mids and have a good deal less bass than the M50's, so they will sound very different to what you're used to with those (not sure if you're looking for a similar sound signature or not, though).
I'd recommend researching more or even posting a thread over at Head-Fi (head-fi.org). Ehile there are certainly some knowledgable audio gurus here on GH, there are a lot more people with experience over there.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #4 on: Sun, 21 June 2015, 18:12:49 »
Buy HiFiMan 400i... not great to take on the go because if you're on the go you realllly shouldn't take fullsized headphones, but they will work (sounding tight) off of a phone, PC, and the nice systems.
Open Box for - $425
Then take a few months and save up for an Aune when they go on sale for $125-150
Offline cmadrid
« Reply #5 on: Tue, 23 June 2015, 13:30:59 »
http://schiit.com/products/fulla
option for a dac/amp that is portable.. I wish I could get wife approval for some nice headphones myself, lol
Offline Sniping
« Reply #6 on: Wed, 24 June 2015, 03:34:15 »
Hey, sorry for the late reply. The DAC helps, but it's not very good value. The M50 isn't that high end so you'd be better off getting a headphone that sounds good out of the box (no amp/dac needed).
The benefit of a DAC is usually overexaggerated.
Offline GL1TCH3D
« Reply #7 on: Mon, 06 July 2015, 18:59:09 »
The biggest change in sound will always come from changing the headphones.
For something portable and good I'd get the NAD HP50 for something in the $200 range or the shure srh1540 for something a bit higher end. (Frankly the new shure headphones have been outstanding. I still hate the sound of the lower end models like the 840 / 940).
As for the DAC question I'd consider a Fiio DAP. The fiio x3/x5 both can be used as DAC / Amp combos through USB or as a music player by itself. The first generation Fiio Daps are really cheap right now.
I personally much prefer spending the money on a nice all in one system (I have the AK240 which can do the same thing as the Fiio + Bluetooth and other streaming options) that's very reasonably sized.
Offline t888
  • CONNECT 14400 ... Welcome to Skynet
« Reply #8 on: Sat, 11 July 2015, 16:59:16 »
I highly recommend getting a USB DAC.  I am using a DAC WOW from hotaudio it was $130 and sounds fantastic.
http://hotaudio.com/products/dac-wow-high-fidelity-usb-dac-for-your-pc-or-laptop
Unicomp ♡ HHKB Pro 2 ♡ Realforce 87u 55g
Offline Bevo
« Reply #9 on: Thu, 16 July 2015, 17:22:19 »
The m50's are great headphones. I'd recommend upgrading your source so either buy a new DAP (digital audio player) such as the Fiio's if you are willing to carry both a phone and DAP around at the same time or buying an amp for the phone such as the Fiio portal amps. Both these options will add a bit of bulk but will ultimately open up a much wider range of headphones you are able to take on the go.
As for the AKG's, i would not recommend buying them as portables as they are open back design and leak sound plus I would not call them a real upgrade from the m50's you already have. Something like the V-Moda m100's sound great just out of the phone so that could be an option.
I recently bought a portable rig myself (Sony nw-zx2 and Shure se846) but that's a bit over the top if you aren't planning on spending over 2k
Offline DrHubblePhD
  • I am star stuff
« Reply #10 on: Thu, 16 July 2015, 17:40:26 »
It's been proven in blind tests that as long as the signal is clean (without noise or popping) there is no noticeable difference between a $20 source and a $1000 source (I would link the artical but I'm on the road). I have JH13s (I wrote a review on GH) and I think that a pair of great headphones was an awesome investment.
Offline ishpeck
  • Life without MX Blues is no kind of life at all.
    • The Ishpeckian Network
« Reply #11 on: Thu, 16 July 2015, 20:31:43 »
When I was using a Macbook Pro at work, I got a new set of Sennheiser 598's and from then on, I heard this constant humming over all my music.  I got a DAC and the hum went away.  Any other headphones didn't have the hum but they also sounded like a tin can with a string by comparison.  Running theory is that the sound card was picking up oscillations of my motherboard/power supply.
My Sennies don't tend to deliver the hum on my desktop machine, tho'.
0:=λfx.x
Offline GL1TCH3D
« Reply #12 on: Thu, 16 July 2015, 20:55:07 »
I've never had a good experience with on board sound.
« Reply #13 on: Tue, 21 July 2015, 09:42:07 »
It's usually more expensive to try and find a motherboard whose engineers paid any mind to audiophile quality I/O.  I've found a couple, but upgrading generally takes all of that away.  Much less expensive and takes less time to just get a good dac that works with any machine/modern device.
Offline nothing4me
« Reply #14 on: Wed, 22 July 2015, 00:23:20 »
Best DAC I can recommend you is O2 + DAC (You can get it amp + dac in one, or separate).
Offline Rodgaroon
  • Size matters, just ask my wife.
« Reply #15 on: Sat, 25 July 2015, 23:26:03 »
Personally I would tell you to get a Schiit stack. Magni 2 and Modi 2 would go well with any of the AKGs on Mass Drop. Honestly a $100 Dac and Amp would be perfect. They even Rock the Hifiman 400i well. For the road get on Shure SE215. They are only $100 so plug them right into your phone. For you first Cans of better quality try and buy something used. Someone is selling the AKG 712 on here for like $260. That's an amazing price.
G6v2 (MX Black) | Poker II (MX Brown) | Compact SQ (MX Clears 62g)
