Author Topic: I-One Lynx R15?  (Read 4087 times)
Offline InSanCen
I-One Lynx R15?
« on: Tue, 29 September 2009, 19:10:12 »
http://www.amazon.com/Ione-Lynx-Optical-Trackball-Mouse/dp/B001KBZ1J8
Anyone used one? Is it any good? I can get it crazy cheap through work (About £10, sorry limited to one only).
Is it worth it, or should i suck it up and get a decent one?
If it's any help, I adore my Logitech MX518, and what (admittedly cheap and poor) trackballs i've used in the past I haven't liked.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline InSanCen
I-One Lynx R15?
« Reply #1 on: Sun, 01 November 2009, 06:17:12 »
Well, I broke down and bought one. It feels cheap, and the side-mounted scrollwheel is awful. The motion of the ball itself is pretty good, certainly better than anything I've tried to date (Nasty stuff so far, not tried a Kensington or Logitech).
Meh... Maybe I'm just not suited to Trackballs. I like the Idea, and the coarse control feels a lot better/easier. The Fine control is just not there, but I'll persevere and see what I can get out of it. When it comes to Input devices, I rarely find this board to be wrong, and I can't see you lot being waaaayyyy off-base about Trackballs being great. If I can get the hang of the Fine Control (I am doing some paid PS work at the moment, so the MX518 is still attached to get the Control I need), then I'll invest in a better one.
If anyone else in the UK is interested, then Maplin has them on offer for £20 at them moment. I paid a lot less than that, but I had Gift Vouchers and Staff Discount to use.
http://www.maplin.co.uk/Module.aspx?ModuleNo=227879
Offline bigpook
I-One Lynx R15?
« Reply #2 on: Sun, 01 November 2009, 06:25:24 »
The amazon reviews weren't too flattering.
 If a regular mouse works for you then...
I use the kensington expert and while I wouldn't use it for FPS games it works great for everything else. For me anyways. Trackball mice take a bit to get used to. If you are still inclined, then get a quality trackball and stick with it for a few weeks. You should know then if its for you.
The kensington orbit, logitech marble are pretty decent mice too.
Offline InSanCen
I-One Lynx R15?
« Reply #3 on: Fri, 13 November 2009, 10:27:41 »
Decided I hate it.
But, having snagged a go on a friends Logitech Marble, I'll be getting one of them.
Anyone want this? Free in the UK, you just cover postage.
