Author Topic: need some guidance with custom keyboard.  (Read 3997 times)
Offline deicide3
« on: Mon, 22 June 2015, 10:09:57 »
hello been long time since i have browsed this forum, so the time came and i'm in need for an upgrade. and sadly what i look for in keyboard does not exist.
i'm looking for custom keyboard that will have: mx dark grey(linear), "tenkeyless" us layout, blue back-light and full case(not "floating keys").
thank you for your time.
Offline SidusNare
  • Do, or do not; there is no try.
Re: need some guidance with custom keyboard.
« Reply #1 on: Mon, 22 June 2015, 10:31:35 »
There are some interesting keyboards over in the classifieds https://geekhack.org/index.php?board=59.0 or you might have to piece together exactly what you want through group buys https://geekhack.org/index.php?board=70.0
If you want something just off the shelf, there are plenty of vendors over in https://geekhack.org/index.php?board=51.0
I personally have a Leopold wit MX Blues I got off Elite Keyboards sporting Round 5 sphericals off 7bit's group buy.  and a Noppo choc mini with MX browns (ebay) with white on black double shots off 7bit's group buy. Also, a bolt-modded silver badged Model M as my daily work keyboard that I took into the office with me.
Sometimes you have to mix and match a bit to get exactly what you want. Its not a cheap endeavor, but worth it if you spend a lot of time behind a keyboard.
To doubt everything or to believe everything are two equally convenient solutions; both dispense with the necessity of reflection. -- H. Poincare
Offline deicide3
« Reply #2 on: Mon, 22 June 2015, 13:07:45 »
i'm sorry but that didn't help me at all
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #3 on: Mon, 22 June 2015, 13:17:26 »
Nevermind.
« Last Edit: Mon, 22 June 2015, 13:19:25 by Blaise170 »
Offline deicide3
« Reply #4 on: Mon, 22 June 2015, 13:26:35 »
i want to buy built keyboard not parts
Offline henz
  • What?
« Reply #5 on: Mon, 22 June 2015, 13:27:13 »
Not to rain on your parade or anything. I had a similar issue once upon a time. So what i did was i picked up a soldering kit, ordered some switches and started watching soldering videos. Got a cheap bord, replaced the switches
So i would suggest getting a used qfr or smth, get your switches, surely you have a friend or acquaintance which know how to solder and have the necessary tools.
From time to time there are some keyboards showing up on Massdrop which has the option to choose swithces(not sure if i have seen linear greys as an option though)
third option is almost the same as option one, but get springs instead from sprit(has a thread in the groupbuys) and get a bord with linear switches(reds, blacks)
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #6 on: Mon, 22 June 2015, 13:46:19 »
You have rather specific needs on a pretty uncommon switch. It is highly unlikely you will find exactly what you want unless you are willing to do it yourself, or ordering a custom made board. That being said, I have seen a Varmilo VA87M with everything you are looking for, except it has floating keys.
Why not try to build something yourself and make it everything you want it to be? Or, alternatively you will probably have to accept some compromise in your requirements.
Offline deicide3
« Reply #7 on: Mon, 22 June 2015, 19:38:20 »
this is exactly what i want!
and no i got no skills for building it myself, and i don't want to **** **** up either.
Offline deicide3
« Reply #8 on: Tue, 23 June 2015, 08:07:52 »
can you give me more info about Varmilo VA87M?
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #9 on: Tue, 23 June 2015, 08:14:04 »
If you want a fully custom built board, it is going to cost you and take a while. Check GON's website. His lead time is through the roof right now.
Or you can order all the parts and pay someone to construct it for you.
« Last Edit: Tue, 23 June 2015, 08:15:56 by iamtootallforthis »
Offline neverused
« Reply #10 on: Tue, 23 June 2015, 08:32:36 »
http://bfy.tw/TWf
Offline deicide3
« Reply #11 on: Tue, 23 June 2015, 08:49:47 »
http://bfy.tw/TWf
i tried to google and they don't even have a website, it only gives me link to either forums or ebay wanabees
is there any other option?
« Last Edit: Tue, 23 June 2015, 08:56:39 by deicide3 »
Offline neverused
« Reply #12 on: Tue, 23 June 2015, 08:55:47 »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #13 on: Tue, 23 June 2015, 09:51:01 »
Are you really that stubborn? Varmilo is a Chinese company so even if they did have a website, it would be mostly in Chinese. Here...
https://www.massdrop.com/buy/varmilo-mechanical-keyboard
Offline deicide3
« Reply #14 on: Tue, 23 June 2015, 20:03:47 »
i see my only option is to wait for the damned drop
Offline deicide3
« Reply #15 on: Fri, 02 October 2015, 03:47:27 »
i think i'm in love
