Author Topic: Can I use Teensy 2.0 to make my Realforce detachable USB keyboard?  (Read 1690 times)
Offline last100yen2
I have Realforce 87U and I would like to mod it to be detachable USB
Can I get Teensy 2.0 board to accomplish this? if so, how should I wire them?
Offline user 18
Re: Can I use Teensy 2.0 to make my Realforce detachable USB keyboard?
« Reply #1 on: Mon, 22 June 2015, 16:42:28 »
You shouldn't need a teensy or anything so complex. All you should need is a little mini USB/micro USB breakout board, wire it up to the appropriate header on the realforce PCB, and you should be good.
See: https://geekhack.org/index.php?topic=50821.0 https://geekhack.org/index.php?topic=40658.msg1023666#msg1023666
Avatar by ashdenej
Offline last100yen2
« Reply #2 on: Mon, 22 June 2015, 17:41:20 »
How do I know which cable goes to which?
« Reply #3 on: Mon, 22 June 2015, 17:42:20 »
I linked you the pinout in your last thread asking the same question :)
Offline last100yen2
« Reply #4 on: Mon, 22 June 2015, 18:09:35 »
thank you!
technicallyvthat should work for usb too?
