Author Topic: Tex 80% case internal connector replacement?  (Read 1934 times)
Offline Johan
« on: Tue, 23 June 2015, 21:38:08 »
The story is basically don't do this **** at 3:30 am, No matter how messed up your sleep schedule is.
The esc key was rubbing against the case a little, so I wanted to adjust the pcb placement.
This is what the thing looks like. http://imgur.com/wxvP6Ne,JguQ1Ce,0ISwLZT#0
I think I can solder the loose wire, But I'd really like to have a replacement if I duck it up more.
So I need one of these things.
Uh, stuff.
Offline Johan
Re: Tex 80% case internal connector replacement?
« Reply #1 on: Wed, 24 June 2015, 07:57:34 »
Never surface mounted a wire before, works though.
Uh, stuff.
Offline sth
  • 2 girls 1 cuprubber
« Reply #2 on: Wed, 24 June 2015, 08:06:16 »
so you broke your keyboard while modding it and then fixed it?
cool  :cool:
Offline Johan
« Reply #3 on: Wed, 24 June 2015, 08:31:50 »
cool  :cool:
Thanks! I thought it was perma borked for a while.
Here's how the solder joint looks like http://i.imgur.com/EjqKkHj.jpg
Can't say its my best work but at least it works.
Uh, stuff.
