Author Topic: QFR with no lights to backlit  (Read 3038 times)
Offline Frigid
« on: Tue, 23 June 2015, 22:39:56 »
I was wondering how hard it would be to take my QFR (http://www.newegg.com/Product/Product.aspx?Item=9SIA0AJ34K6133&cm_re=quickfire_rapid-_-23-129-002-_-Product) and convert it to all backlit.
Offline Oobly
Re: QFR with no lights to backlit
« Reply #1 on: Wed, 24 June 2015, 13:30:06 »
Very hard... The PCB doesn't have pads or support for LED's.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #2 on: Wed, 24 June 2015, 13:58:07 »
You know what this is? Justification to by a new keyboard! :p
Offline user 18
« Reply #3 on: Wed, 24 June 2015, 13:59:43 »
Definitely a ton more effort than it's worth
Avatar by ashdenej
